Question about Aloha Housewares (93645) Ceiling Fan
Fan doesn't work
I have a home trend 3 speed ceiling fan model #C552CA(CH). the fan wouldn't turn so i moved the reverse switch and it sparked. fan still won't work. switch has 6 wires; 2 orange, 2 yellow; 1 white; 1 black. what is needed to fix fan?
5 Suggested Answers
  • 250 Answers
SOURCE: My ceiling fan, model, 5745, has a broken switch.
ANy electric store will have different switches (lowes and home depot do too) just make sure you bring the old one with you. The colors of the wires shouldn't make too much of a difference just the amount
Posted on May 17, 2010
SOURCE: I have the aloha model 5745, need to replace speed
when I turn my fan on, it will not come on, I can come back in the room in a few minutes and it will be on, whats my problem
Posted on May 22, 2010
  • 3287 Answers
SOURCE: Ceiling fan has the normal
Do NOT attempt to connect this fan to this ceiling box!
In the USA, a color code is employed to quickly alert the electrician about the voltages found in circuits. Black, red & blue insulated wires with a white colored neutral wire indicates a standard residential 120 / 240 volt system. Brown, orange and yellow wires with a gray colored neutral on the other hand, indicates a common commercial or industrial 277 / 480 volt system.
Since I don't know where you live, but it could be the USA (or other country that also observes this color scheme for system voltage identification), I urge you to contact a qualified electrician. If you insist of checking it out yourself, please exercise EXTREME caution. Accidental contact with 277 volts will burn and most likely kill in an instant.
If it is determined to in fact be a 277 / 480 volt system, the fan you selected will not be able to be connected to this circuit as it is a 120 volt fixture. Connection will result in damage, fire or worse.
I hope this helps. Please rate my reply - thank you!
Posted on Jan 03, 2011
nascarnbronc
  • 6 Answers
I tried the Home depot stores and Lowes Stores solutions years ago and found out the switches are too different to work everytime.
If anyone needs switches or capacitors for ceiling fans that are hard to find, I can help. I have a source for them, I also have photos for the wiring color codes for the Shine top 102 nascarnbroncosfans@msn.com
Posted on Jan 07, 2013
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
    The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
    May 15, 2010 | Dryers
    Lemon chain switch
    To get a free switch you will have to take it out and take it back to where you bought it and they will replace it or just take the whole thing back and get a brand new one because of the switch. thats the only way you will get a free switch.
    Apr 21, 2010 | Aloha Housewares (93645) Ceiling Fan
    Hunter ceiling fan-just installed -possible speed control problem
    Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
    Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
    Jul 21, 2009 | Hunter Ceiling Fan Control Switch
    I'm trying to install a used Shell Electric Manufacturing (Holdings) Co. LTD. model U42 ceiling fan, however it appears that the internal wiring has been moved around and in some cases cut off. I am...
    the black rectangle is a capacitor! there is no diode in a ceiling fan, usually the white wire is the common or neutral , the blue is for lighting and the black one is for the fan
    Mar 10, 2009 | Dryers
    Hampton Bay ceiling fan - will not reverse
    It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
    Dec 07, 2008 | Kitchen Appliances - Others
    Ceiling fan does not reverse with remote
    Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
    Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
    Aloha Housewares (93645) Ceiling Fan Logo
    51 people viewed this question
    Top Aloha Housewares Dryers Experts
    Steve
    Mike Carew
    john h
    Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
