Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture is too red
Cant get colour right seems there is no green and picture is too red and i cannot change it in the picture menu
    Sergeant:
    Champion:
  • 324 Answers
Sounds like you may have a bulb out, you can pull the screen off to access it but you have to very careful with the screens or you will damage them, only clean with isopropyl alcohol and of good quality, there will be three bulbs in there, red blue green, their location and direction is very important, so dont move them, if they all work clean then put the screens back on, and see if you can adjust the direction from the menu
Posted on Jul 03, 2010
BEKO 32WLU530HID only red colour except on internal Menu
Sounds like a loss of green--I am in USA and Scart term not used here but I am aware it began as internet slang for Component hookup--which does use a Green, Red, and Blue input cables---if that type then suspect no green from source or cable bad etc.
Apr 25, 2012 | Televison & Video
What causes green tint to picture
should be a setting in the menu for changing the green colour on the screen, should be able to adjust green blue and red to get perfect picture settings for the user.
Oct 20, 2011 | Hitachi Televison & Video
For some reason the piicture seems to have changed to a more of a green shade
u need to access the ad9883 sub menu in the ez main menu and enter the values as original and the colour will balance i have the same problem but am unable to activate the ad9883 sub menu cos the scoll/ cursor pointer cant select it for its not highlighted in white like the others hence the pointer skips it, but once u get in u will be able to balance the colour by keying the right values
Nov 13, 2010 | LG RE-44SZ21RD 44" Analog Television
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
How do you adjust color, color seems too green?
There should be colour settings under the "picture" tab in the menu. In the colour settings you can change the level of green, blue and red (the 3 that make white) Here you can scale the green back to make it closer to equal with blue and red
Jul 06, 2009 | Hisense TL1700 17 in. LCD Television
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
