Question about Maytag MER5775Q Electric Kitchen Range
The bake or broiler functions on my electric oven wont work
My oven would not preheat. I checked and found bake element broken. Relaced the bake element but it shorted out( touching metal ground). Now neither bake or broiler work. Multi- meter reading for resistance = 0 on both elements. I'm afraid I shorted both elements - maybe more. Before I purchase 2 new elements is there any way to check for further damage? I don't hear the clicking sound in the bake or broil setting. I also read that a circuit board may be fried. Help! thanks, Mike
  • 1 more comment
  • mike pipito Jul 06, 2010
    I'm concerned that there is more damage than the elements. As stated the brioler element worked until I replace the broken bake element and shorted it by grounding to the frame. Now neither work. The VOM ohm test reads Zero on both elements. Also I do not hear any clicking like before as I try to preheat. Circuit board??
    Thanks, Mike
    Very helpful. Logical and informative. Answer appears to be knowledge and experience based.
  • mike pipito Jul 07, 2010
    Thanks, your insights are very helpful. I did gain access to the board but don't see any obvious damage/ discoloration. I have several questions regarding the board: 1. do the plug in connectors unplug from the (white) front board or do I have to remove all the wires. 2.Can i relace the white front board only or do I have to repace the green board underneath as well. 3 It appears the front board(white) can snap off the green board with the solder connections - the left side moves easily but the right side seem stuck - i dont want to force it. I was hoping to get a good look at the solder connections. By the way I do smell a slight odor from the green and black plug in connectors but no obvious burn marks etc. Thanks for your patience. MIke
  • 6,784 Answers
HI. I'm afraid that you have shorted out the two element relays located on the main board. This will require you to have the main board(ERC/PCB) replaced, asap. The elements are also damaged. A good element will have ranges around 19 to 115ohms, when tested on Rx1 settings. Due to the fact that the relays are not clicking as designed, this will confirm the additional damaged that is located at the main board.
Replace the elements and main circuit board.
Posted on Jul 06, 2010
  • 2 more comments
    Thanks. Not what I wanted to hear but what I feared. Is there a sure fire way to test the relays in the main board with a VOM before I invest more $. Mike
  • Michael Masters
    Michael Masters Jul 06, 2010
    There are no set test points on this particular board. You have very strong indicators that are signaling failure at this board. A quick visual inspection should reveal possible discolorations at the relay junction points(solder points). I'm sure there will be some discolorations visible on the board in question. The strongest indicator will be the absent relay action(clicking). When a relay is energized, it should click. This is not happening, as stated in your post. That indicator will confirm the local relay damage present.
    These boards are not designed to be repaired, unfortunately. They can only be replaced.
  • Michael Masters
    Michael Masters Jul 07, 2010
    HI again.
    "do the plug in connectors unplug from the (white) front board or do I have to remove all the wires."
    The plugs are ribbon based(small set). They can simply be pulled away. You will need to release the catch, of course. This is plug n play technology. No need ot remove every single strand. each plug has a grouped design that can be pulled away. Be sure to mark the location so that you do get confused when installing the replacement board.
    "Can i replace the white front board only or do I have to replace the green board underneath as well."
    The white front board will be your touch pad interface. You can replace this if you wish, but the green PCB is the focal point here. That is the one that is damaged. Some models incorporate the touch pad and main control board into one whole device. if this is the case, replace the entire assembly. If the two can be separated into two pieces, just replace the green PCB with the exposed circuitry.
    "It appears the front board(white) can snap off the green board with the solder connections - the left side moves easily but the right side seem stuck - i don't want to force it. I was hoping to get a good look at the solder connections."
    OK, do not force the two apart. This may be a integrated design. In this case, the assembly will need to be replaced. The smell you have discovered will most certainly be from burned silicon or plastic connectors.
  • Michael Masters
    • I have just verified that your control board is an integrated device. The white part(touch pad), can not be removed. The entire assembly must be replaced. It is designed to be one whole device. The white part will not separate without brute force.
    Genius:
  • 1,417 Answers
Are other part of the oven working ?
if the answer is yes then go a hard to get the new element but make sure that you are buying the same side or you should go to the store together with the bad element ,
let me ask you a question that think you most have ask your self , will you be able to fix up the element after buying it from the store if the answer to my question is yes then do just that but if the answer to the question is no the you will have to invite a technician along with you.
thank you and thank for using fixya.
Posted on Jul 03, 2010
  • mike pipito Jul 04, 2010
    Just to be clear. The broiler element was working until I shorted out the bake element replacing it- now neither element works. All the other functions on the range work ( stovetop. light, clock etc. ). I have no problem replacing the elements myself but I want to be sure that the circuit board or some other part is not damaged. Whats the best test for defective element ? How about circuit board?
Ge double oven turns off during baking
WHEN THE RESISTOR EXPANDS UNDER INTENSE HEAT IT MAY BE TOUCHING GROUND AND TRIPPING THE BREAKER.
Jun 18, 2015 | GE Kitchen Ranges
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Oven warms to desired temp then cools down
Check your bake element. Unually ovens use both bake and broil elements to preheat and just bake element to keep temperature. Your bake element is probably burned out.
Jan 30, 2011 | GE Profile JT912 Electric Single Oven
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
Seems that my oven is only heating on the top not the bottom.
sdounds like your bake element is shorted
some ranges uses both to preheat
Oct 08, 2009 | Ovens
Digital oven pops breaker as oven starts to light
You have a direct short. A wire or component has touched ground .Gas or electric?electric check connections at bake and broil elements in back.Gas look for broken wire /connection at ignitor or ERC ,(control board)
Jun 20, 2009 | Tappan TGF320 Gas Kitchen Range
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Maytag MER5775Q Electric Kitchen Range Logo
216 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
