TO CONNECT TO THE WIRELESS SERVER I NEED A SECURITY KEY
  • 53 Answers
It's on the bottom of the router
Posted on Jul 03, 2010
I want to secure my belkin 54 router, its not secure now
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is 192.168.2.254
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
May 03, 2011 | Belkin (54G F5D7230UK4) Wireless Router
I put in the wep key put it doesnt let me in wifi and what is ssid how do i put wifi manualy
The Nintendo DS only supports certain types of Wireless Security, the Nintendo site specifies what version DS supports what versions of Wifi Security
An SSID is the name of your wireless network, so it's what you see when you try to connect to a wireless network at your home
to put in Wifi manually you have to put in the SSID, Wireless password, and depending on if your router is set up as manual or automatic, you may have to put in your IP Address and Subnet mask and finally you need to put in a primary DNS server, your primary DNS server IP Address is the IP Address of your router.
Mar 30, 2011 | Nintendo DS Lite
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
Security key
Use an Ethernet cable to connect your desktop/laptop to one of the LAN ports on the router. Launch Internet Explorer, and connect to the web-server "inside" the router. Run the "Wireless Networking Setup Wizard", to enter an SSID, enable 'WPA' encryption, and to set a security-key or password or pass-phrase.
Aug 22, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Password on wireless router
OK, You listed this under a print server router. I looked up the DP 300 print Server router and restricting access to the router is not an option. If you are actually talking about your Wireless router for your home network you need to look in the user manual or access the router and go through the configuration pages for the wireless settings and set Security to on and then Select either WEP or WPA as the security format, which ever is supported by your computer, then enter a Security Key. The Key can be anything as long as all devices that are going to use the wireless have that same key entered with the same security method selected. Your user manual should explain better where these option are located.
Jul 26, 2010 | D-Link DP 300 (DP-300) Print Server
Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Jan 01, 2010 | Linksys WRT160N Wireless Router
My toshiba a15-s129 wireless internet is not working all of a sudden, It connects manually (through cord) but cannot connect to wifi. It does however found a wireless just doesnt connect. I have tried...
many symptoms can be at fault here first check the device drivers of the wireless card on your computer next check the security of the network where you connect to. You need a valid key for web security or others, also laptops have a switch or FN key that activates and deactivates wireless cards on some systems check that as well and if all fails check the settings on the router that your connecting to. is there enough ips to go around from the DHCP server that your router is giving out.
Dec 01, 2009 | Toshiba Satellite A15-S129 Notebook
Trying to connect Epson stylus photo PX700W to aol wireless network. Am being asked for WEP/WPA info and security codes etc.
The wireless network is protected with a WEP/WPA security key. You need to get this key from AOL with our membership.
Oct 19, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
I have an ipod touch that I am trying to connect to my qwest wireless internet. I have entered the WEP key and it shows that I am connected but when I attempt to open Safari it says that it can't find the...
  1. Turn on your iPod.
  2. If not at the home screen, press home button.
  3. Tap settings button.
  4. Tap wi-fi.
  5. If broadcasting your ssid, choose from the 'choose a network' list.
  6. If not broadcasting your ssid choose "other" under 'choose a network'.
  7. Under 'name' type your ssid.
  8. Tap 'security' if you are using security and select your security type.
  9. Tap the 'other network' button to get back to network setting.
  10. Type in your security password, which is your key in your wireless network setting. Important *you must use key 1* in wireless setting.
  11. Click 'join' after you have typed in your security password.
  12. Your network name (ssid) should show in 'choose a network' with a check mark next to it.
  • Use security with your wi-fi connection.
  • Use the first key password in your wireless network setup screen, key 2, 3, and 4 will cause the iPod touch to not connect even if the password is correct.
Sep 24, 2009 | NetGear DG834G Router
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
