Question about Home
Security sensors i am replaceing a security sensor the house wires are red white and blue the sensor wires are brown blue and red which goes where. thanks russ
  • 827 Answers
Best thing on this is to contact a alarm company to help
Posted on Nov 24, 2013
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
Feb 09, 2018 | Heating & Cooling
20056 Freestar. Where is the fuel rail pressure sensor located?
I looked up info for the 05. It looks like passenger side rear of fuel rail. Four wire connector, wire colors, gray wire with red tracer-- red wire with pink tracer--lt blue wire with white tracer-- brown wire with white tracer. If you find those wire colors at the connector that should be the sensor.
Number 1 is the vacuum connector fuel pressure sensor, it just makes sense that it plugs into the fuel sensor.
Jun 07, 2015 | Ford Freestar Cars & Trucks
2013 r1 code 22 error
replace the sensor in the left snorquel
Fault code No. 22 Symptomicon1.png Air temperature sensor: open or short circuit detected.
Diagnostic code No. 05 Air temperature sensor
Orde
r
Item/components and probable
cause Check or maintenance job
Reinstatement
method
? Air temperature sensor coupler
? Main wire harness ECU coupler
? Check the coupler for any pins
that may have pulled out.
? Check the locking condition of
the coupler.
? If there is a malfunction, repair it
and connect the coupler
securelyicon1.png.
Reinstated
automatically if
a normal signal
is received.
2 Open or short circuit in wire harness. ? Repair or replace if there is an
open or short circuit.
? Between air temperature sensor
coupler and ECU coupler.
(Brown/White?Brown/White)
(Black/Blue?Black/Blue)
3 Defective air temperature sensor. ? Execute the diagnostic mode.
(Code No.05)
? Replace if defective.
Refer to "CHECKING THE
INTAKE AIR TEMPERATURE
SENSOR" on page 8-91.
May 13, 2014 | 2006 Yamaha YZF-R1
Wiring a d2 eberspacher diesel night heater up
how much it coast black & decker Heater product model no . or07d
thank you
Dec 22, 2013 | Heating & Cooling
Bosch 02 sensor downstream on a 1996 Jeep grand cherokee 4.0 motor. I have no wire harness to match the colors to. bosch has two white, one grey and one black. Jeep has orange/green,black/brown,black/blue...
The two white are the heater
The black the ground
The gray the O2 Sensor output,
you back probe to check Voltage
& Switching Times
The vehicle wiring harness does not have to match
the sensor, BUT -- you need to have the same
connector on the sensor
If you have a universal cut & splice, you have junk,
and we given the wrong part
Get a Bosch or NGK, OEM sensor & just
plug it in
Jun 23, 2011 | Jeep Grand Cherokee Cars & Trucks
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
Hi, I have a 2007/8 Yamaha R1...............I changed the ECU unit and the clock is showing a code 22 error.................please assist me ASAP.....................!!!!!!!!!!!!!! Dave cell no: ...
Fault code No. 22 Symptom Air temperature sensor: open or short circuit detected.
Orde
r
Reinstatement
method
1 Connections
the coupler.
securely.
Reinstated
automatically if
a normal signal
is received.
(Code No.05)
thx to Mr Ravine.
Feb 12, 2011 | Yamaha YZF-R1 Motorcycles
I have a f350 crew cab 1997 5.8 and while drivin and after take off the truck loses power and shakes then stops seems like only when accelerating this happens.
Hello! There are two sensors that will cause this problem both can be tested...If you have a volt meter...If not, let me know...
#1 is the Throttle Positioning Sensor (TPS)...A black round device that is bolted to the throttle body with a three wire connector...Wire colors are...Gray/White...Brown/White...And Gray/Red...Using two safety pins plug them into the rear of the in place connector on the Gray/White...And Brown/White...Place + probe of meter set to read 5 volts on the Gray/White...And - probe on Brown/White...Start engine...At idle must read less than 1 volt (.85)...As you slowly increase throttle meter must rise smoothly to 4 volts at open throttle...If voltage jumps or acts erratic the sensor is defective...
#2 is the Manifold Absolute Pressure (MAP) sensor...Also mounted to throttle body...Three wire connector with the following wire colors...Light Green/Blue...Gray/Red...And Brown/White...Using the same technique...Pin the rear of the connector on the Light Green/Blue...And the Brown/White...Place + probe on Light Green/Blue and - probe on Brown/White...Turn key to on (don't start)...Record reading...Move Light Green/Blue probe with safety pin and push it into the Gray/Red wire...Record reading....Also check the vacuum line which is connected to the Map Send results...
Cost...TPS=$55............MAP=$95
Guru.................Saailer
Aug 27, 2010 | 1997 Ford F350 Crew Cab
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Home Logo
29 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
