Question about iRobot Roomba 530 Robotic Vacuum
On the white roomba 530 - does not fill big dust cup anymore
Does not fill big dust cup anymore, just the one where the paper filter is - is something not working right, or low battery, or what?
    Problem Solver:
  • 5 Answers
If brushes clean and still not turning try turning manually about 20 turns and re try
Posted on Aug 28, 2010
  • 27 Answers
You may need to clean the ends of the roller brushes.pull both out pull off the funny looking yellow ends and clean out hair ect.
Posted on Aug 07, 2010
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Shark Vacuums
Shark navigator lift away turns on but no suction
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Oct 17, 2016 | Shark Vacuums
Why does robot roomba 530 repeatedly stop and say to clean brushes
I think it's telling you to flip it over, open up the brush compartment, take the brushes out, remove everything wrapped around them, replace them and close it up. I suspect that your brushes are wrapped up with something.
Next open up the filter compartment, dump it into the trash, pop or slide out the filter and bang it into the trash can. Give it a quick rinse in the sink to wash off the fine dust still on the filter. Let it dry and insert it back into the filter compartment.
May 16, 2014 | iRobot Roomba 530 Robotic Vacuum
Dyson dc 40 loses suction
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Oct 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson hose has lost suction
Ava B.
May 14, 2012 | Vacuums
Bissell carpet cleaner does not suction
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Jan 17, 2012 | Bissell 1699 ProHeat Clear View Upright...
Dyson DC32 Animal has lost suction.
Ava B.
May 02, 2011 | Vacuums
My 530 roomba just spins no beeps nothing like that just spins why won't it go anywhere anymore.. cleaned it
Your bump sensors are malfunctioning. I had the same problem. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend.
Jan 01, 2011 | iRobot Roomba 530 Robotic Vacuum
Machine just rotates same spot in a circle
I just repaired my 530 roomba last night. I used a sewing machine brush and cotton swabs. On the bottom of the roomba there is a face plate with four screws. Loosen each of these four screws and remove the face plate. DUST EVERY OPENING YOU CAN SEE, but do it gently. Use NO chemicals. Then there is the area that holds in the brush and roller cartridge. Again, loosen those four screws and remove the corner brush's screw and completely remove that little brush. Then you will carefully remove the "case" holding the brush and roller cartridge.DUST EVERY OPENING YOU CAN SEE. Wipe all the silver contact points..plates on the bottom of roomba and one inside the brush and roller cartridge. At this point, I dampened a paper towel ever so slightly with some window cleaner and wiped and dried those contact points. Then using the brush attachment on my vacuum I gently went over all areas of the body of the roomba to dislodge even more dust. Once that is done, reattach all the parts in the reverse order of how you removed them. I charged my roomba overnight and this morning she was charged and worked as if she were brand new! I hope this helps. If my solution works for you,please contact FIXYA and rate my advice.
Nov 18, 2010 | iRobot Roomba 530 Robotic Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
389 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
