Question about Bosch 24 in. SHU53 Built-in Dishwasher
We left our Bosch shu6802UC on delayed start last night. In the morning the dislpay showed C.L. but the motor was still running. When we turned it off and opened the door there was water in the bottom. We checked the filters and they were OK. We checked the plumbing for the sink and the disposal and it was OK. We tried to reset by pressing the Scrub Wash and Delicate Buttons at the same time and turned on the power. Both the lights for those buttons kept blinking and after waiting five minutes I turned it off.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To remove this error you’ll need to
Press and hold "Scrub Wash" & "Delicate/Economy" buttons until "CL" goes off display. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • 2 more comments
  • schoenbj Jul 03, 2010
    I tried what you suggested. I pressed those two buttons at the same time and turned the power on. The display did not show CL, but it showed 2.0. Should I have held the buttons anyway. If so, how long?
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    Unplug it and plug it back after 5-10 minutes. If it shows the error again then hold those two buttons till the time CL disappears not more then 5 minutes. If still the issue is not resolved then the control panel should be replaced.
    I do not know what error you are refering to, unless the display of 2.0 is an error code. Please inform me of the error you are refering to.
    I turned the circuit breaker off for 10 minutes. Then I held those two buttons and turned the power on and again got the display of 2.0. I held the buttons down for 5 minutes and during that time the 2.0 remained in the display and the two lights kept on blinking. After 5 minutes I momentarily released the two button and the pressed them again. This time the display changed to 0. and I contiinued to hold the buttons down for a little time but nothing happened.
  • Rylee Smith
    Rylee Smith Jul 04, 2010
    As I
    said earlier that you’ll need to replace the control panel.
    Thanks
    Rylee
I used the dryer last night with no issue. When I went to use it this morning, I pressed the start button, I heard the motor run, but the drun did not move. After a second, the motor stopped trying. ...
i would say the belt that turns drum is broke,slipping or jumped off motor.try running without clothes in it.if drum dosent turn belt is broke or off
Oct 22, 2013 | Electrolux EIED55H Dryer
Determine age of Bosch dishwasher
This is the FD number eg
9001
add 20 to first two numbers 110, ignore the first number this is 2010, the last two numbers is the month 01=jan
8804 would be 88+20 108...2008 april
If you can't work it out please comment with FD
May 28, 2013 | Bosch 24 in. SHU6802UC / SHU6806UC...
Power light goes on but no water
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
Jul 07, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Leaking from under SHU6806UC
Hi, Motor seal...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Apr 04, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Five second delay with pump
check the intake of the pump. It may be clogged with sludge or debris.
Oct 02, 2008 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
63 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
