Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
The grinder does not work on my cuisinart grind n brew
  • 6 more comments
  • chrisnap49 Jul 06, 2008
    The grinder only partially grinds. It makes a low-pitched sound as it grinds, but then leaves large chunks of coffee bean in the grind basket, resulting in weak coffee. We have already tried unsticking the rotating thing that the basket sits on when it had completely stopped grinding previously.
  • fmuldoon Sep 16, 2008
    I have the same problem with the grinder. It makes an odd sound and leaves chunks in the grinder cup. I ran the grinder twice and it ground the remaining chunks. I'm not sure if it's the grinder blade or the motor which generates the grinder.
  • wohaney Oct 01, 2008
    Grinder used to grind well, now leaving chunks in the grinder basket.
    How to fix this anyone?
  • parable7 Oct 10, 2008
    The grinder blade got stuck and I was able to break it loose then the next day the grinder motor won't kick on to grind the beans. I also noticed that where the blade attaches to the shaft seems very worn. Does anybody know how to get this crazy grinder to kick on...I NEEEEED my coffee:)- ktn
  • fmuldoon Oct 28, 2008
    I was having the same problem and thought the problem might be the blades in the bean basket. I purchased a new basket and it worked for a few weeks; however, the problem is back.
  • cderasmo178 Nov 03, 2008
    My grinder is making a terribly loud noise and is leaving chunks of beans also. The coffee unit is two years old.
  • modern2 Nov 03, 2008
    Yes my machine makes a harsh noise when grinding.
    Is it the motor? Can you replace it?
  • prdube Dec 04, 2008
    My grinder makes funny noises and it smells like something is burning. There are pieces of plastic left behind, and I am unable to remove the grinder w/o a knife to pry it.
I just sent an email to the following address: customerservice@cuisinart.com
explaining the problem. I'll repost here when I hear back.
Posted on Oct 28, 2008
Why the h- doesn't cuisinart answer this recurring issue?
Posted on May 18, 2008
Have a cuisinart grind and brew. It's not working. The power light is blinking. No other lights will turn on and/or operate. Help.
This is caused by calcium building up within the machine. or insufficient power supply.This can cause injury.Make sure you troubleshoot it or see that power supply is enough.
Jul 21, 2016 | Cuisinart Grind-and-brew 12-cup Automatic...
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
Why does Cuisinart grind and brew coffee not go into the pot but runs all over?
with a small brush to loosen any grinds on the machine walls and around blade, once it is loose you can tap it out of the grinder, you will find a small bristle paint brush or bottle brush works well.
Sep 09, 2014 | Cuisinart Coffee Makers & Espresso...
Grinder on Cuisinart Grind and brew does not work anymore.
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
933 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
