Question about Whirlpool RF111PXS Electric Range
Neither the bake or the broil elements will turn on, rest of oven works fine
  • 116 Answers
SOURCE: Oven won't work
It is likely that the safety fues in the back of the unit has failed. This is accessed by removing the back panel of the unit. It is usually located just to the left and up from the center of the back wall. be sure to remove power from the unit before removing the back cover.
Posted on Apr 27, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
SOURCE: Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Posted on Jun 11, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My range ,GLES388DSA, lower oven element does not turn on.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 15, 2015 | Ovens
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Whirlpool RF111PXS Electric Range Logo
46 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
