Question about Radio Communications
I need help with programming my BC148XLT scanner please
    President:
  • 2,761 Answers
Programming the BC148XLT is pretty straight forward:
1. Power the scanner ON.
2. Press MANUAL to stop scanning.
3. Enter the number of the channel to be programmed.
4. Press MANUAL again.
5. Enter the frequency, including decimal point (ex: 250.145).
6. Press E to enter the data into memory.
7. Repeat steps 2 through 6 to program remaining channels.
More detailed information can be found in the scanner's operating manual, which you can download/print here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Posted on Jul 05, 2010
Uniden bearcat scanner BC148XLT-1 Can't program it because it is locked out
Try manually unlocking each channel by selecting it and then pressing the LOCKOUT key. That will normally clear the channel for programming. If that doesn't fix the problem, power the scanner OFF, then press and hold the MANUAL, 2, and 9 keys while powering the unit ON. That should restore the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
Bill B
Aug 11, 2010 | Radio Communications
I have a uniden bearcat scanner model#bc148xlt and it seems to not want to take the local frequencys and it comes up error when you hit the enter or e button
You didn't mention what frequencies you're trying to program. BC148XLT coverage ends at 512 MHz, so you will get the error message if you try to program anything above that. Also, you must be sure to include the decimal point when programming a frequency into the scanner. I hope this helps.
Need the manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 20, 2010 | Radio Communications
Lost codes for bearcat scanner BC148XLT-1
If you mean what is on a particular channel that say the police in your area is on then go to http://www.nationalradiodata.com/resources-frameset.jsp?resources-citiesandcounties.html . Type in that complete address and it will bring you to a page where you click on the state you live in and if you want to go by city or county frequecies.
Sep 12, 2009 | Uniden Office Equipment & Supplies
Alot of static very little talking
Check you antenna on the scanner. You are describing loss of signal to the scanner. It could be the antenna, the antenna connector, the scanner its self.
Check everything over, Try a better antenna.
Aug 02, 2009 | Radio Communications
Need help on programing my 20 channel 10 band scanning radio
Here's a link to get the Uniden owner's manual... Look for the grey box in the upper right corner.. this will get you up and running ... You may also want to do a google.com search for " radio frequencies" and " your state here".. that will help you find the local radio freq's.
Here' s the link to the manual
May 30, 2009 | Uniden BC248CLT Base Scanner
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
May 16, 2009 | Uniden BC340CRS Base Scanner
Need codes for scanner
http://www.radioreference.com/apps/db/
Apr 16, 2009 | Uniden BC248CLT Base Scanner
Radio Communications Logo
203 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
