Question about Peg Perego John Deere Gator HPX Ride on Toy
No forward gears just reverse
No forward gears just reverse battery is fully charged
any ideas
Thanks
    Habit-Forming:
  • 156 Answers
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Posted on Jul 08, 2010
    President:
  • 2,702 Answers
If it go's backwards its not a motor fault,,,its the gear change "switch"
this is a "dule throw dule pole switch" it reverses the curent from the battery to make it go forwards or backwards check the switch out,,,it may have a busted wire or the switch its self may be faulty
Posted on Jul 03, 2010
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
When you turn the car on it just goes flat out in reverse no forward gear any ideas thanks
Switch is stuck in reverse mode. Fix/replace the switch. Or until you fix it, reverse the battery connection so it will go forward.
Sep 20, 2015 | Cars & Trucks
No power to the wheels in forward or reverse new battery fully charged
verify that the battery is fully charged by testing it with a multimeter, also test your charger with a multimeter, they both should be putting out at least 12 volts
Sep 18, 2011 | Peg Perego John Deere Turf Tractor
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
2005 tuscon won't start turn the key there is silence the gear shift is locked up
Hi
Here is what you need to do.
Replacing The Stop Lamp Switch
Ignition off.
Remove the panel under the dashboard on the driver's side.
Removing The Stop Lamp Switch .
Press the stop (brake) lamp switch, from the side of the connector, completely forwards.
NOTE: A number of clicks should be heard and felt when pressing.
Disconnect the connector.
Press the brake pedal as far down as possible.
Pull the white bushing (1) as far forward as possible.
Press in the two locking lugs (2) on the reverse. Remove the stop lamp switch.
Thanks for contacting fixya.com
Oct 25, 2009 | Hyundai Tucson Cars & Trucks
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
Sep 12, 2008 | Makita 6932FDWDE 14.4V Impact Driver
Peg Perego John Deere Gator HPX Ride on Toy Logo
874 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
