Question about Sony DVP-NS710H/B DVD Player
How does one hook up a DVD/CD to a digatal TV
    President:
  • 1,285 Answers
Well since you have a digital tv (you have all sorts of jacks in the back or side panel)...your dvd has 3 (rca) cable wires (yellow/red/white)..we need to plug these three wires into the back of tv where its video in (depending on your set it might say dvd/digital in or whatever)...once you have did this in order to see the dvd using the remote switch the source (between tv/av1/av2 or cable)..remember your tv stays on ch 3....to get back to your regular tv again using the remote for the tv switch the source to tv/cable''
feel free to rate the help
Posted on Jul 03, 2010
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
I purchased a philips dvd burner. I originally had it hooked up through my comcast cable box. Unfortunately I unhooked everything but I am trying to remember how to hook up the burner so I can burn...
hook the cable back up to dvd and have the out going to the tv. note the dvd & tv must be set to Ch 3.......go to set up / menu on both tv / dvd change source to cable (not air broadcast)
feel free to rate help
Aug 08, 2010 | Philips (JR4DVDRWK/00) DVD+RW Burner
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
HOOKING UP A MAGNOVOX BLUE RAY ,CD PLAYER. WE HAVE COMCAST CABLE.
it gets plugged into the tv not the cable. audio out of dvd into tv and video out of dvd into tv
May 10, 2009 | Televison & Video
I have the RCA RT2500 model and I am looking for directions to connect tv, DVD, gaming, Cable Box, etc are there anywhere on line I can find it? thank you
the back should have a squared in box around the inputs like dvd vcr sat tv cd, dvd and sat have svideo and component a/v plugs, the vcr just has component rca a/v ports, tv and cd are just for audio, then you also have the option to hook up optical for dvd and sat. just plug your vcr into the vcr box and hook up svideo or the yellow monitor out plug to your tv, hook in the speakers and turn that baby up.
Jan 07, 2009 | RCA RT2500 System
Hooking my tv to the bose
u wann hook up this unit so it plays muci throw biiggger bos system > doesnt big system have cd player this cd only not tv dvd unless it says dvd now then use outputs on back to tv input but i think it only cds
Feb 02, 2008 | Bose Wave Radio
Connect dvd/cd player to GE OR OTHER BRAND TV
if you dont have the audio video imputs RCA jacks on your TV, you can hook it up through a RF MODULATOR you can hook up to any tv this way. they come with instructions as well as the magnavox also shows how to hook one up.
Dec 10, 2007 | Coby DVD-207 Portable DVD Player
Sony DVP-NS710H/B DVD Player Logo
116 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
