Question about Tappan TGF657 Gas Kitchen Range
I have a Tappan gas stove that takes forever to heat up (oven) and I smell gas before it starts to heat. Help?
  • Douglas Jensen Jul 03, 2010
    Hello, I have some questions for you for clarification. Is this propane or natural gas? How old is it? Describe the burner flame: Is it yellow or blue, or blue with yellow tips? How many inches long is the flame on each side of the burner? Do you have soot build-up? Wipe the walls of the oven and see if you get black fingers. Do you only smell gas when you use the oven? In other words, you don't smell gas when it's off or when you use the stove top burners, right? Your answers will help me better determine what is wrong. Douglas
  • bettyruger5 Jul 08, 2010
    Hi, It is about 10 years old. Natural gas. Blue flame. No soot. I only smell gas when I turn on the oven-it takes like 15 minutes for the oven to start heating up. Thanks-Betty
  • 494 Answers
Thanks for answering my questions. It sounds to me like your oven's safety valve is going bad. There have been many times when I am at a customer's house and it has been a while since they used the oven, and it seems to take forever to light the oven. Just tapping the oven safety valve with a wrench or handle of a screw driver is all that's needed to open the valve and light the burner. As long as your oven's igniter glow bar is lighting, (glowing orange or sparking), then the oven safety valve is your problem. It is a silver rectangular valve in the far back bottom of the oven with the orifice on top of it and the burner tube coming down over the orifice. Try tapping it and see if that works. Otherwise, just have it replaced. Douglas
Posted on Jul 08, 2010
I have a tappan gas stove. the stove top works but the oven doesn't heat up enough to cook and i can smell gas. I checked the gas line and it is tight with no leaks. i am wondering what could it be and...
You could do the repair yourself. Much more information is needed. Is your oven spark ignition or hot surface ignition ? A valve may be opening only partially. This can happen on a hot surface ignition system when the glow bar is starting to malfunction. Need to know more details to be of real help.
Tom
Aug 10, 2010 | Tappan TGFS26C Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven makes an exploding sound when put on "bake" smell of gas
sounds like the oven valve is leaking slightly. just as a precaution i wouldn't use it till you can get a repair man out there.
Jan 02, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan TGF657 Gas Kitchen Range Logo
373 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
