Question about Dryers
I own a Maytag Ensignia dryer model#MDG3757AWW.I started to disassemble it. As I was sliding the top of it backwardds I observed a flash (spark). I looked in the area of the flash ( just below the timer/ start knob )and there was no exposed wires that could have caused this flask( spark ). It blew my breaker which I reset. When I went to try to start the dryer back up it would not start.i hear a slight noise coming from the timer/start knob.i have had 2 techs look at it. They both claim that I have proper amount of electric going to all componets but it just will not start. The 2nd tech is a good friend of mine. He took parts ( timer unit door switch and motor ) and replaced them but to no avail.whats your thoughts?
Aytag ensignia dryer model # is MDE7657BYW
Go for item 5 on this diagram. You can buy it off appliancepartspros.com
Parts for Maytag MDE7657BYW Control Panel Parts
Aug 24, 2014 | Maytag Dryers
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag gas dryer will not start
check the power make sure its correct
Jun 07, 2010 | Maytag SDG3606A Gas Dryer
How you open a maytag ensignia washer
The older models had screws at the base to remove. The newest ones have spring clips instead of screws1c7ff10.jpgthis is a dryer but basically you washer fron panel comes off like this when you release the spring clips on each side with a simple putty knife.
May 12, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
Jan 21, 2010 | Maytag Dryers
Maytag ensignia dryer MDE7657BYQ. Are the flaps
yes it can be tightened, you would have to take off the door, there should be 2 screws on left and 2 on right, then you would have to take off the dark brown like bolt on the left and right, there is a long L shape clip that holds top to front. Once you lift top tightened the bolt or add a bolt to the baffles..
Sep 11, 2009 | Dryers
Belt replacement instructions for Maytag Ensignia model MDE4658AYW electrical dryer
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
Jul 24, 2009 | Dryers
Dryer Drum Scrapping
You probably need to replace the slides:these wear down and cause the noise you are discribing.900bee5.jpg
Dec 22, 2008 | Maytag SDE2606 Electric Dryer
Dryers Logo
254 people viewed this question
Top Dryers Experts
