I have a mitsubishi reefercooling system then itis used for delivering perishable goods then it broke down so i try to fix the wiring then somehow when i was about to bring it back together i got lost by its wiring ihop u can give me the wiring diagram of theref itself thank u
  • 53 Answers
94 mitsubishi 3000gt will not turnover
Most starter solenoids are on the starter. There are 2 to 3 wires going to the starter, the big one from the battery is for the starter motor it's self. The smaller one is from the ign switch to the sol. That's the one I'm guessing your having problems with. When you turn the key do you get a "click" sound or just nothing? If there is a click then your getting power from the key. And the heavy gauge wire is not delivering power to the motor. Check at battery or if they use a terminal block
Apr 03, 2017 | 1994 Mitsubishi 3000GT
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
I need wired controll unit for mz AL mx5021 since I broke the original one.IS there a way to deliver this spare part to Serbia?
Hi name Rui, have you tried searching it on ebay or other sites that might deliver it..... just try searching it on google but 1st try ebay...
Jul 17, 2011 | Altec Lansing MX5021 Computer Speakers
What is the coolent reserve tank for???? IF broke does it need to be fixed immedatley? Mine is busted and I was wondering if my car is going to overheat now. THANKS
The coolant reserve tank is a medium for the radiator to breathe. Water passes from the radiator to the coolant reserve tank and fort.
The car might not necessarily over-heat if the coolant reserve tank is broken, but it is advisable that you replace it to enable it serve its purpose within the operations of the car engine.
Good luck.
May 27, 2010 | 2004 Toyota Avalon
2003 mitsubishi eclipse wiring diagram
I own a 2003 mitsubishi spyder eclipse GT and my alarm fob broke off its key chain so I havent been using it lately (waiting for replacement). Today I went to use my car (unlocked and opened the door with the key) and the alarm activated. The car still starts but I have to wait till the alarm gos through its cycle before I drive anywhere (embarassment of course). How do I disengauge the alarm system till I get the new fob?
Feb 01, 2009 | 2003 Mitsubishi Eclipse Spyder
I have Mitsubishi eclipse '98 GS.Cigaret lighter just stopped working. Checked the fused and replaced but it's still doesn't work. I was using a portable compressor to pump some air in my tire. I need it...
so you replaced a blown fuse to the cigar lighter and it still dosent work?.. then the wiring was compromised before the fuse blew..you need to repair bad wiring to cigar lighter and/or lighter itself internally melted /failed due to your air pump asking for more electricity than the cigar lighter could deliver..once repaired do not use the air pump there again ..good luck
Dec 02, 2008 | Mitsubishi Eclipse Cars & Trucks
1994 jeep grand cherokee
You cant disable it realy..but you can use the key to unlock the driver door or the rear door. Both have a alarm shut down wire..Also that wire could be broken in the drive door boot...very common. The wire is purple and yellow..Touching the wire to ground shuts the alarm off. Just make sure if its broke that the end going into truck is the one you groung on the frame. Also locking the doors from the inside with the driver door open is what activates the alarm. That wire can also be found in the drivers side kick panel.....
Jul 18, 2008 | 1994 Jeep Grand Cherokee
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
