Question about Toshiba e-Studio 35 Copier
Toshiba e studio 28 feeder on copier does not work. makes noise as if it is taking the paper in but no paper is taken in.
  • 31 Answers
You may need to to some new feed rollers and seperation pad. jaime
Posted on Jul 16, 2010
My Toshiba e studio 28 keeps saying to Add Paper but the paper tray is full. How do I fix this?
Tray motor is bad or gearing has fallen out of place. Could also be paper present sensor in the machine above the tray.
Apr 05, 2010 | Toshiba e-Studio 232 Black and White...
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
Paper Error
The paper lift housing is cracked. The clicking noise is made by the lift gears skipping teeth.
It needs to be serviced...in the mean time, you might try feeding 11 x 17 paper through the manual feeder (bypass tray). Or if you need many 11 x 17 copies, it is possible to set another paper drawer to 11 x 17 size...just set the plastic tag in the front of cassette to LD so the machine knows what size of paper to expect (if tag is set incorrectly, machine will jam EVERY TIME)
Jun 10, 2009 | Toshiba E-STUDIO 450 Copier
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Misfed document feeder
just check properly all document feeder may bi there is a piece of paper in feeder if not just check all sensors and levers .may bi some sensor is dirty clean all sensors in paper path and check all sensor levers .may bi some lever is jammed.mian jee
Jan 20, 2009 | Toshiba e-Studio 205 Copier
CALL FOR SERVICE estudio350
You can by-pass by putting the paper on hte glass and making the copies.
there is most likely a pice of paper or paper clip in the feeder
Oct 03, 2008 | Toshiba e-Studio 350 Copier
Jamming
I have a couple of Toshiba machines with finishers in my office. I don't know if they use the same one as the 28 uses.
Is the rollers where it is getting stuck at have a dark cover with the number 1 on th handle?
Aug 14, 2008 | Toshiba e-STUDIO 28 Printer
80 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
