Question about Fuji FinePix E900 Zoom Digital Camera
We returned from vacation at the beach. We kept the camera away from the beach but the wind was strong when we used it on outdoor patio. The camera now gives "focus Error" message when it is turned on and the lens will not close when turned off. It is a Fugi E900.
Yep turned mine while turning on and off and it works!! yea thank you!<!-- from fixya rte -->
Posted on Aug 11, 2010
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 04, 2010
How can I fix the rip on my patio umbrella
why bother, most of them are made in China and like most stuff we are a throw away society, it will cost you plenty for glue and material if you still chose to fix it, The most I get frmo umbrellas int eh desert sun is barely a year.
May 31, 2015 | SONOMA outdoors Crank And Tilt Solar Led...
The camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen ) pl. help asap as i am with my family for a vacation pl...
Problem with the Samsung Digimax S730 Digital Camera the camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen )
Jul 14, 2011 | Samsung Digimax S730 Digital Camera
It will light but goes out after 3-5 minutes. Tank is full and there was no wind.
Chances are that it is the thermocouple. Ive seen many on their way to going bad that held the pilot valve open so it kept the pilot lit, but after a couple minutes of burning, the vent gases pull the flame away from the thermocouple just long enough for it to quit. You could replace it , or try to adjust the pilot flame orifice in the direction of the thermocouple so that it has better contact with the thermocouple.
Apr 10, 2011 | RTO Bernzomatic Brushed Nickel Patio...
Im not getting enough fuel pressure to create a decent flame, everything lights as it should and stays lit but its not letting enough pressure out. Could it be the pressure regulator on the line thats...
Check what type of fuel, if using butane on cold days it will stuggle to stay alight, always use propane on outdoor patio heaters, propane will work in vvery low temperatures. If using propane check for leaks, do a leakage test, found this patio heater specialist site very useful.
Feb 21, 2011 | Endless Summer Blue Rhino 235000...
Ice smells/tastes like chemicals
discard ice keep making it till it goes away(dont eat ice) if doesnt go away-further investigate!!! :)
Jul 06, 2009 | Hotpoint HSS25GFP Side by Side...
Power shuts off on its own
Yes the beach, two of camera worst enemies, water and sand. The camera should be taken apart to check for sand and water damage. Camera that are even exposed to air around salt water will develop problems.
Jul 02, 2009 | Kodak EasyShare M1033 - black Digital...
Cant zoom on my DSC-W80 sony cybershot after droping it in the sand at the beach
If you found good information in my solution, please be sure to rate it! Thanks!
Oct 25, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Lens/ resolution problem
I you have been on a beach there are chances that your camera get get sand inside. you have to get it cleaned before use. to not try to operate the camera in the same condition.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Fuji FinePix E900 Zoom Digital Camera Logo
81 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
