My border doesnt complete the four sides what would be the problem
  • 487 Answers
Its the size of the page, reduce this and your boarder will fill in
Posted on Jul 04, 2010
DVD leaves 1/2 border on left side of screen in wide mode. what is Cinema aspect ratio for? Distorts Adjustment?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Feb 01, 2016 | Proscan Televison & Video
How do you make lines appear on an excel sheet?
I'm not sure what Version you're using, so I'll assume after Excel 2010.
At the top of the page, under the Home tab and directly under the Font window, there is an icon which looks like a window frame (dotted all around except on the bottom edge).
In your spreadsheet you have to select the area you want to work on. You can select a single cell to add lines to or the whole spreadsheet. Click on the icon I described above and a menu box will pop down. There many choices which allow you to select lines on all sides of your work. I prefer the one at the bottom which says 'More Borders'. With that window you select the edges you want lines on, the thickness/type of the line, or put an outline.
I think that's enough for now and I hope that gets you started.
Aug 12, 2014 | Microsoft Excel 2010
I have a 2004 f 150 the four wheel drive will not completly engage
you have a switch on the side of the transfer case and you have a actuator in the differential front end if you dont use your four wheel drive often that can be a problem if you have no reason to use it stil once every three months engage your four wheel drive and ride around your neiborhood sometime the switches get stuck tap on those if that doesnt help loosen them up replace them
Sep 28, 2010 | 2004 Ford F150
Image does not to borders of the screen, even with...
Does your Windows "desktop" and "wallpaper" completely fill to the borders? If not, then you either need to reconfigure your video-adapter, or use the video-adapter controls to "widen" and "stretch" the image, to fill the viewable area of your screen.
May 21, 2010 | Sony VAIO PCG-K33 Notebook
UPDR150 Thermal Photo Printer: My Sony UPD-150 is printing on only 3/4 of the 5X7...
One of the pins is bent. Its not closing completely so when it prints the heads are not touching the media evenly causing this effect. We have four of these printers and have seen this before. You need to take some pliers and straighten the bent pin in the door to match the one on the opposite side. These pins are located near the top edges of the printer door.
May 17, 2010 | Sony UPDR150 Thermal Photo Printer
Border in each column
Follow this steps to achieve that.
  1. Click on the column you want to have a border, On the Page Layout menu click Borders
  2. On the Borders and Shading window go to the Borders tab not the Page Border tab
  3. Select the borders you prefer then on the Apply to: drop down select Paragraph. Click ok then your done.
May 12, 2010 | Microsoft Windows XP Professional
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
Boarders and titles
A name and date is very simple you can go to the control panel- Tap twice on the top left of the welcome screen and enter your four digit code default is 9999 - Click on the ikon at the top of the screen relervant to text - You can then type a Company name, Date or Tel No: - select font colour size and position - I would suggest white - You then click on
the add text button and it will be on all prints until you change it or switch it off - We put our Name, Tel No and a number to designate which printer it is as we have five of them and if we have a problem I know which one needs fixing.As to adding a company logo and date
in the borders section you would first need to create a border design
in photoshop or other editing program import that into the border creating software that came with the machine then save this to a borders folder on you computer - Then if you have a compact flash card in the expansion slot on the inside of the ribbon carrier door remove it
and add your new border to the borders folder on the card and replace it in the machine. If you havn't then copy the border directory from the CD
supplied with the machine to you hardrive add you new border to this folder then copy it to your new compact flash card - Place this in the expansion slot in the side of the machine as above.When you now
switch the machine on and enter the print mode select the border ikon and you should see all your borders - Select the one you require and print - If you print different sizes you will need to create a border for each size - You can also go to the control panel and set the machine to add a border every time it prints but I have never needed to do that but
it will but in the owners manual and won't be to difficult I assume.
Jun 11, 2009 | Sony SnapLab UP-CR10L Digital Photo...
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
