Question about EuroCave Refrigerators
Twisted Case: I recently acquired a vintage E170, 160/180 bottle, 3-temperature EuroCave which appears to be in good condition except the entire case is slightly twisted. The door is accurately flat and is aligned correctly on the hinge side, but on the handle side the opening is about 3/4" wider at the top than at the bottom. I can manually twist the case enough to close that gap, but of course it springs back when I let go (and the problem has nothing to do with the way the feet sit on the floor). Any suggestions?
  • ted4861 Jul 06, 2010
    Not sure I understand that solution -- any more help?
  • 3,083 Answers
Wow, could be a tough one here. There could be a sprung, broken support inside, that would be really hard to fix. One easier solution might be to adapt a wall support to exert sideways pressure to help or make up the gap. If you try to spring the whole unit too far back, there is a chance of doing more damage, so I wouldn't suggest that. If you try to make a wall-supporting bracket, you may have to anchor the other side, in possibly the middle of the unit, to allow a sideways torque. Sounds like a nice unit, hope you get it operational.
Posted on Jul 07, 2010
    Guru:
  • 468 Answers
I am not an expert in Refregrators but yes I have found a very helpful link for you. For your reference you can go through the link below
http://www.repairclinic.com/Refrigerator-Repair-Help
Posted on Jul 06, 2010
  • 484 Answers
There is supposed to be a screw that is holding the case together so it will not spring up back after you have manually twisted the case to close the gap.
Try to look for a way to get the cast hooked up together. you can try using a drill to drill that part and put in a screw there to hold the case together. If you can do this, the spring wont be too free to spring the case back open.
I hope this technique works for you.
Take care
Posted on Jul 04, 2010
What would be the value of my vintage watch?
It looks like a gold filled case and of course it's a standard wind. I would put a value on your watch if it is in running order of $100.00. This may not be what you could get for it but if it was being sold in good running condition that would be a fair price. Hope this helps, gabe.
Sep 25, 2014 | Bulova Ladies Watch Wind Up Vintage
What does the term vintage mean in regards to wine?
The vintage is the year found on a bottle of wine indicating the harvest year of the grapes from which the wine was made. Vintage year characteristics are primarily determined by weather conditions from that year. This is where the phrase "the '75 was an excellent year" came from.
Feb 03, 2013 | Wine & Spirits
The freezer is not getting cold. Recently, I replaced the fan motor and it is running and blowing good. I turned the temperature alarm setting to the off position because it will sound due to the warm...
I would replace the defrost termination thermostat. They were a frequent failure item on
Frigidaire units I service, causing this condition. Around 8 to 20 dollars depending on
vendor. Also check the defrost timer as I have found at least one that was stuck due to
mis assembly. (the replacements are from a different vendor). Hope this helps.
Jun 26, 2011 | Frigidaire Freezer FFU1212D
Hi, I've recently acquired a Pfaff 230 s#5 150 268, need parts
HI. Sew4Less.com (http://www.sew4less.com/index.php) has parts for your Phaff 230, including belts, a bobbin case, and both service and repair manuals.
SewingManuals.com (http://www.sewingmanuals.com/index.htm) has both the user and service manuals.
Hope this helps!
Happy Sewing!
Robbie
Mar 21, 2010 | PfaFF Sewing Machines
Garmin 260w won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
My transfer case has started to leak from a small weep hole on the passenger side of the rear case, just above the fill plug area It appears to be leaking out only when driving the truck -- Any idea why...
The internal oil pump has worn through the case - poor design i was told by the transmission shop. Talk to them, they see it all the time. I just replaced mine last fall except i had to rebuild the entire transfer case after it locked up. The half case is only about $300, my rebuild was about $2000 after neglecting the problem.
Aug 12, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Radiator problem, I think?
Not likely, but you can flush the entire system, and that would give you an indicator of the condition the engine is in internally. Smell the overflowing coolant, if it has a burned or exhaust like smell, you need to look at your engine gaskets.(Cyl Head gasket) especially. in a worse case scenerio, the heads themselves may need to be looked at. When you get a cracked head, you typically get a condition where the pressure the engine makes, pushes to coolant back through the system end up in the overflow bottle. I love jeeps, so good luck with this repair.
Aug 05, 2008 | 1988 Jeep Wrangler
Refrigerators Logo
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
