Question about Kenmore Elite 45986 Front Load Washer
I don't have a manuel
I need to know how to add powder detergent booster to the washer
    President:
  • 1,937 Answers
See the following Sears site for PDF versions of their manuals.
You'll have to select the right one for you washer since it appears that there are three different Model Numbers that use the same stock number.
http://www.managemylife.com/mmh/owner_manuals/search?query=45986
Posted on Jul 04, 2010
2 Suggested Answers
  • 32 Answers
SOURCE: How to add liquid detergent and powder booster at the same time?
any booster would go in the detergent dispenser,should not be a problem if you are doing warm washes.if you do alot of cold washes,check for build up and clean from time to time.
Posted on Sep 28, 2008
Gltf1670as1can you use powder detergent in ?
Good Morning Friend,
I understand that you want to know if you can use powder detergent in your Frigidaire washer, model# GLTF1670AS1. Below are the advised steps for the detergent dispenser of your washer.
• Add measured detergent to the detergent compartment of the dispenser drawer.
• Detergent is flushed from the dispenser at the beginning of the cycle. Either powdered or liquid detergent can be used. Note: Liquid detergent will drain into the washer drum as it is added.
• Low sudsing detergent is recommended for this washer. Use the manufacturer's recommended amount.
• If low sudsing detergent is not available, a reduced amount of regular detergent may be used. Because
reducing the amount of detergent may reduce cleaning, it is important to pretreat stains, sort carefully by color and soil level, and avoid overloading.
• Detergent usage may need to be adjusted for water temperature, water hardness, size and soil level of the load.
• For best results, avoid oversudsing.
Hope this is helpful.
-Best Regards-
WP
Jun 05, 2014 | Frigidaire Washing Machines
White powder in washer after clean cycle
If you live in an area with hard water, the white powder is probably hard water residue / deposits. Most detergent does not clean hard water deposits anymore because there are new laws that required a change in the ingredients of dishwasher detergent. Here's a product that was created to solve this exact problem. Add about 2 tablespoons to your normal detergent. It's all-natural & made from dehydrated orange peels! They will send a free sample if you ask for one. www.CloudyDishes.com
Hard Water Stains Cloudy Dishes Dishwasher Detergent
May 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
A friend just gave us this washer and dryer so I don't have a manual. Can i use powdered detergent?
Yes you can use powdered detergent..it should be rated HIGH EFFIENCY and have a logo similar to this one on the packageoldtech2332_1.gif
All major brands make HE detergent,tide,cheer,all....... ect ect
GENE
Oct 27, 2011 | Maytag Neptune Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Oxiclean
Mix one ounce OxiClean powder with your powdered detergent in the detergent dispenser of your front loading washing machine.
OR
Dump one ounce OxiClean powder into the washing machine before you add clothes.
May 15, 2010 | Kenmore Front Load Washer
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent will not dispense
generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Mar 07, 2009 | GE WSXH208A Front Load Washer
Sep 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
