Question about Hand Tools
Not starting not getting gas srm 231echo trimmer will run momentarily when primed with gas
  • 760 Answers
Trimmers are know to have problems when left with old gas in tank. They use a little diaphragm to pump fuel, with two little flappers in a gasket that act like check valves. This rubber gets wrinkled up and the check valves won't close. Buy a carb rebuild kit either online or through your local power equipment dealer and rebuild it. There are only about 5 parts in the kit.
Posted on Jul 04, 2010
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
Husqvarna SRM 225 It starts fine but dies once you give it gas.
I was having the same issue with my 128LD string trimmer. I called a local Husqvarna service dealer and they told me the issue was a result of the ethanol in the gas. They suggested I find ethanol-free gas (aka 'Pure Gas') and try it. [http://www.pure-gas.org/ was the best resource I could find for this]
After disposing of my old gas and filling the trimmer with premium grade, ethanol-free gas (with Husqvarna brand oil mix) and applying 3 squirts of carburetor cleaner to the carb, it runs radically better.
I hope that helps you too. I know how frustrating that can be.
Jul 21, 2010 | Husqvarna 225cc Hedge Trimmer 22" Cut HVH...
Husgvarna string trimmer stahls.
Try getting some carb and choke cleaner and spraying down the carb. You might have some varnish in the carb and it won't let the fuel flow properly. My ryobi 4 cycle trimmer does that every year. I clean the carb and it usually runs decently.
Good luck
roundo4
Aug 09, 2009 | Garden
Will start with starting fluid but will not keep running.
check your prime bulb and fuel lines for leaks just a pin hole would cause it not to prime
May 31, 2009 | Garden
Hand Tools Logo
41 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
