Question about Car Audio & Video
How do you set the clock on a Clarion MO350 marine radio/casette player? Rick
After spending an hour, here is how you do it. With the radio playing, press and hold the BAND button, until the word MANUAL displays in the bottom left. Then press and hold BAND, plus DISP (4). The radio will then go into Clock mode. You can change the hours by pressing the left scan, and the minutes by pressing the right scan. When finished, press the BAND button. To exit MANUAL mode, press and hold the BAND button.
Posted on Jul 28, 2014
  • 5 Answers
SOURCE: set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Posted on Dec 11, 2009
Suraido
  • 195 Answers
SOURCE: I HAVE BEEN GIVEN CLARION PW 547204 CAR RADIO
Usually, all aftermarket stereos have a standard wire colo code. Red being the positive current coming from the accessory switch, yellow being the current directly from the battery, black being ground and so forth. Simplest way to wire this up will be to go to your local car stereo shop and ask them for the wiring haress that goes on the dash side made specifically for your car model. It will come with the right color wires, so once you got it you just need to pair up the wires together and plug it into the dash like it was an OEM radio. The red goes with the red, yellow with yellow and so forth. Just be careful once you hit the speaker wires which are white, grey, green and purple since they have a positive and negative one, but its not too hard, just pay attention to the stripes or marks on the wires, one is plain colored and the other is striped, plain being positive and striped being negative.
Posted on Jul 07, 2009
kenw392
  • 2226 Answers
SOURCE: A Clarion car radio cd player in an 206 Peugeot
the cd mech. is bad. you need to replace the cd mechanism.
Posted on Sep 18, 2009
  • 4876 Answers
SOURCE: lost radio code for peugeot 106. Clarion Radio
The PU-9971 uses a hardwired code system inside your radio and will require specialist advice.
Try here
www.ukbookshelf@aol.com
as they are the only source I know that will help you for free
Posted on Dec 12, 2009
digecorp
  • 92 Answers
SOURCE: I cannot remove a Clarion ARB2170E car radio/cassette.
If you are using the tools designed for this, check that there are no retaining screws at the rear of the unit.
Posted on Apr 12, 2010
I have a clarion m455a marine raidio in our new boat. It has two cmrc3d remote control stations. niether one of them work. Why
Sorry I can't help you...but wanted to let you know you are not alone. I bought a 2007 Chap last March and have the same problem. I've covered all the basic/common sense troubleshooting but can't get them to function. My frustration is that the displays work so the clock/radio station is displayed but nothing in regards to controlling the deck.
Aug 08, 2010 | Clarion M455a Marine Cd Receiver
Set clock on m2455 radio/cd
since i don;t know which version you have of that unit here is a link with manuals just pick the version and it will tlel you how to set your clock.
Clarion
Mar 26, 2010 | Clarion M255 AM/FM Marine CD Player
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion marine radio m275 i need a instruction
you can get the instruction book in the following websites.
www.bizrate.com/marineelectronics/clarion-m275-marine.../compareprices.html
www.amazon.com/Clarion-M275-Marine.../B000PHFVKW
www.crutchfield.com/ISEO...020M275/Clarion-M275.html
Jul 26, 2009 | Audio Players & Recorders
Radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
Jun 16, 2009 | Clarion Boating
Setting clock on stock radio/CD/casette player in 1999 Dodge Ram
push and hold the clock button until the hrs flashes then use tuning button to change numbers or if your radio had 2 small pen tip buttons that read hrs & min pushing these with a pen tip will set the clock
Dec 03, 2008 | Car Audio & Video
Clock setting for Clarion DXZ555MP Radio / CD Player.
Just go to the website and click on the 'download manual' link on the right side. Here is the page on Clarion USA, for your cd player.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
There you can download your owners or installation manual in PDF for free. Nice to deal with a company like them isn't it?
Sep 29, 2008 | Clarion DXZ555MP CD Player
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Aug 05, 2008 | Clarion DXZ665MP CD Player
Arx 1970 car cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Jul 11, 2008 | Clarion ARX6670Z Cassette Player
Setting the Clock
Mdaly, Automotive radio is not really my fortay but this problem is fairly simple so here goes: 1. Press and hold the BND button and then press the DISP button to display the clock. 2. Press and hold the BND button and then press the DISP button for a couple seconds or longer to put it in set mode. 3. Press the search up button to set the current minute 4. Press the search down button to set the current hour 5. when finished press the BND button again and the clock is set... If you would like the manual you can email me privately and I'll be glad to send it... premtech@willapabay.org Bill
Jun 06, 2007 | Clarion DB-125 CD Player
Car Audio & Video Logo
170 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
