Question about Whirlpool GHW9100L Front Load Washer
Can I change the side the door opens? - Whirlpool GHW9100L Front Load Washer
  • 259 Answers
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Posted on Jul 03, 2010
Change Door
there should be two plastic covers or two screws on the oppisite side.simply unscrew the hinge from the side its on flip the door the oppiste way.remove the door mechanism that is on the frame and put the mechanism onthe oppisite side and rescrew the hinge on the oppisite side
Apr 28, 2010 | Whirlpool GEW9250 Electric Dryer
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Apr 16, 2010 | Amana ARB1917CSR Bottom Freezer...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Is it possible to change door to open other side?
yes if there are screw holes to mount hinges on the other side and the handle is removable. this is not the case on all fridges but most you can .consult with your local dealer or handbook to be sure
Oct 05, 2009 | Refrigerators
Drivers side door not working
You need to change the power door regulator on the doors , to make sure they are not defective please check the power door fuse ,if they are blown out please change them if they don't open then you need to change power door
regulator on your car...
Good luck..
Apr 26, 2009 | 1996 Toyota 4Runner
Can you change the way the door opens on the neptune washer
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door/covers open
dear sir; check it out on the side door left hand side (if you face door) have piece plastic door switch actuator isn't broken, change door !
Dec 26, 2008 | Ricoh Aficio 450 Copier
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
215 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
