Question about Fisher and Paykel Dryers
My ed56nz f & p dryer keeps stopping after a short time and i have to keep re-starting it ccan you please tell me what the problem is and how i can fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
Dryer knob won't advance when set on sensor drying but will on timed drying
Hello. The dryer has a pair of sensor bars mounted on the front of the filter holder. They look like long metal rails(about 6 inches or so) and are about 1/2 inch apart. When the wet clothes touch these rails, they electrically short across them, which then tells the control board to keep drying--the clothes are wet. As the water is removed from the clothes, this "keep going" signal gets less and less, causing the dryer to count down and eventually stop. There might be a problem with the wires going to these sensor bars or with the control board. If the dryer keeps going and won't shut off during "sensor dry" the wires could be shorted or the control board might have a loose connector or is defective. Since the unit is so new, the chances of lint build-up being the culprit is remote.
Aug 15, 2015 | Maytag Bravos X MEDX600XW White Electric...
Why does my 30 amp 250 volt Time -Delay cartridge fuse keeps blowing out at the fuse panel for my clothes dryer?
better check the heating element sounds like it's shorting out it is the power drawer in any dryer
Feb 22, 2015 | Maytag Dryers
Dryer keeps blowing 30 amp fuses
usually one of 2 things,either the 240volt heating element is shorting out to the element housing or the dryer drum motor has bad windings or the end bearings are dried out causing the motor to work harder and draw excessive current to start and keep running
Oct 23, 2012 | Amana Tandem 7300 Washer and Dryer Stack...
Roper elec dryer starts and runs for 10 sec then stops runnning
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Roper RES7646KQ Electric Dryer
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
Open Questions:
Dryers Logo
67 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
