Question about Vacuums
My simplicity 7 series vacuum belt turns the agitator (beater brush) turns freely by hand when the vacuum is unplugged or off but when I turn the vacuum on the agitator does not spin even though the belt is moving. Could there be a worn out part at the agitator pin where it connects to the flywheel that the belt is connected to?
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
  • 3 Answers
SOURCE: DC14 Dyson vacuum, not vacuuming carpets, beater
possible bad roller or bad clutch assy
Posted on Mar 07, 2009
  • 83 Answers
SOURCE: beater brush won't spin but belt is intact and ok.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Posted on Jul 30, 2009
SOURCE: Simplicity 7 Series Vacuum. Suddenly stopped.
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Posted on Dec 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: I need a new roller bar or beater brush for
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 14, 2010
"Eureka - Pet Expert HEPA Bagless Upright Vacuum - Mystic Purple" is BRAND new and burning! I literally had soot on my hand and up my nose and mouth after using it just now. I've only had it for 24 hours....
Sounds like the beater brush is frozen and the drive belt is burning up.
Check your directions on changing the drive belt for the beater brush. When you remove the beater brush, clean as best you can. At each end of the beater brush you will find a plastic clip. These clips hold the beater brush in the vacuum. Add some WD40 between the brush and the clips. Turn the clips by hand and be sure they turn freely. Reassemble and at the same time, put on a new drive belt.
If this solution is of help to you, please take the time to add a Thumbs Up to my profile for the assistance. Thank you. Paul
Oct 10, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 13, 2010 | Vacuums
My bissell helix cleanview vacuums brush doesn't spin
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
The brush roller will not engage although the belts look good. Hoover upright windtunnel.
Sep 12, 2010 | Hoover Vacuums
After installing belt...broke
Sep 12, 2010 | Bissell 3522 PowerForce Bagged Upright...
Cannot get the brush to rotate when vacuuming
Sep 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
THE BRUSH ISN'T TURNING, EVERYTHING ELSE IS WORKING.
Sep 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Vacuum turns on but the brush is not rotating
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Sep 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
