The drum inside our front loader washing machine is loose and makes a horrible knocking noise while in the spin cycles. How can this be fixed?
    President:
  • 2,702 Answers
It could be fixed,,, but it sounds like drum bearings worn out thats not going to be cheep,,,or it could be the steady spring/s if one has fell off or just snaped the other is trying to hold all the weight of the drum and it cant do all the work so the drum swings around on the spin cycle battering the inside of the washer,,,this will pull off the water pipes and wiring to other parts like the motor,,,you could wip the top or back off and look inside you will see if the spring has come off,,it will be laying in the bottom
Posted on Jul 03, 2010
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Kenmore front load washing machines knocks
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Drum is really loose and when hits spin cycle makes loud noise
Most front loaders are pretty much the same and it sounds like your tub bearings are going bad. There is also a problem in some front loaders where the drum arms corrode and break. You won't know until you pull it apart. If you are doing the work yourself it depends on the parts you need. You can knock out old bearings and match some up.
If you are paying someone, it may be cheaper to buy a new washer..
Jan 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kncking and f error
If you hv no manual at least write your model number. You could also look for "solved problems" in this site where Kenmore is featured. Most likely u will find your solution
Apr 07, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
