Question about Mitsubishi WS-55511 55" Rear Projection Television
When i turn on my mitsubishi projection screen tv i get a blue screen saying the input is locked use the 10 keypad to enter your personal code, then press enter to view. i dont the code, what should i do?
  • 10,515 Answers
This system can lock each channel or different channels on ANT A and ANT B as well as locking each of the EXT inputs, so you should confirm what is locked before trying to unlock.
1. On the remote, set the TV/VCR switch to the TV position
or depending on which remote is being used Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY PAD) and the INPUT buttons check each channel and input to establish which channels and inputs are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show the selected antenna and channel or input. The display is superimposed over the picture. This display will indicate that the channel or input is either locked or unlocked. In the lower middle will be instructions to use the 10-key pad or SCAN buttons to select the desired channels (or the INPUT button to change antennas or select the EXT inputs). At the bottom of the screen will be instructions on how to change the current LOCK status (if unlocked use the ENTER button to lock, or if locked use the CANCEL button to unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111) and then press the ENTER button.
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are locked, or, use the INPUT button to select the external inputs that are locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely canceled.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 03, 2010
2 Suggested Answers
  • 23 Answers
SOURCE: blue screen says this tv is locked enter your personal code using 10-keypad then press enter to view this tv-my daughter pressed the cable remote & this happened this is the only remote we have&use
What brand is the TV. I would call the manufacturer tech support. If you have the manual the number could be in one of the back pages. If you don't have the manual search the manufacturer online. They usually have a support link with a phone number.
Posted on Apr 24, 2009
Code to unlock VS-4003R
Go into the Menu and in one of the set up pages see if it has a selection for monitor. If it does, change it to tuner.
Hope this helps,
Skyassoc
Jun 20, 2009 | Televison & Video
Mitsubishi VS-5004R
oh its a serious problem first find out the user manual and check whether there is any thing about this in it.
Dec 20, 2007 | Televison & Video
Mitsubishi tv
you will need the remote to unlock
the set try this link here for the
remote
http://www.remotes.com/
you might try this with the remote
press 9 and qv at the same time on the
remote
Dec 05, 2007 | Televison & Video
Blue screen says this tv is locked enter your personal code using 10-keypad then press enter to view this tv-my daughter pressed the cable remote & this happened this is the only remote we have&use
Apr 24, 2009 | Televison & Video
Tv keypad on front is locked and can't find remote
after reading a similar issue on fixya about another person having a similar problem and holding down the setup button for 10 seconds, I tried it on my television (although I don't have a setup only a menu button) and it worked. Thanks.
Jan 13, 2009 | Televison & Video
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
OR:
unlock).
NOW GO TO STEP #6.
unlock).
NOW GO TO STEP #6.
locked.
unlocked.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Green Gun does not come on
my tv comes on but it says your input is locked enter your 10 diget code press enter but i dont no it
Jul 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
