Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 1998 Craftsman garden tractor (917.273030) with a 20 Hp Briggs & Stratton (407777). I have "cherried" her and she runs GREAT. Problems: 1. Over the winter the mice made a home under the engine cowling and chewed through the wiring harness. I repaired the breaks and the system charged itself. Then the system stopped charging, so I replaced the battery and the wiring harness. When the mower deck is engaged, the ammeter drops to negative 5. Any suggestions to fix this? 2. The mower deck will not engage when I pull the PTO switch. I checked and checked the ignition and PTO switches. I seat switch works well. The engine will not turn over if the PTO is engaged. What would you suggest I do?
  • 532 Answers
When the mice cut the wiring harness the connection you made was not properly done. I still believe this is an electrical fault.
Try to check the wiring and make the connection is okay
And also check the voltage coming out of the battery.
Goodluck.
Posted on Jul 03, 2010
  • eksmills Jul 04, 2010
    I have checked the connections on the new wiring harness several times. They are good. I even jumped some of the connections. Still, no charging. I suspected there might be a bad leg on the ignition switch so I took it off, inspected and cleaned it. No marks or sign of excessive wear or damage. I did the same for the PTO switch. Still, no charging.
    To clarify, when I refer to the wiring harness I replaced, I am only talking about the two wires under the engine cowling that lead to the two magnetos (armatures).
    Further, to clarify, I have a Craftsman 46 inch, garden tractor with a 20 Hp Briggs & Stratton
What spark plug for a 19.5 hp briggs & stratton
what is the settings for the spark plug gaps in a Briggs and Stratton 19.5 engine 46 in riding lawnmower
Jul 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton 19.5 HP engine
just had the same problem found the internal jets in the carb plugged took it apart and soaked it for a couple days runs great now
Apr 22, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What type of oil do I use for Craftsman 42" Briggs & Stratton 17.5 hp Gas Powered Riding Lawn Tractor for oil change
Only use SAE 30 if using conventional oil. Briggs is real specific about that. I highly recommend using synthetic oil in ALL lawn equipment. You can use a multi-viscosity oil like SAE 10W-30 if you use synthetic, but straight 30 weight if using conventional. The brand is up to you.
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
18.5 hp briggs 2006 model 407777-0174E1 flooding
If the key is left on it will open the solenoid but it still shouldnt leak unless it has a peice of dirt or foreign debree in the carb clean the bowl out also in the future I have always put a fuel inline shutoff valve on the fuel line for about three bucks never have a problem with excess fuel just remember to turn it on and turn it off
Nov 06, 2009 | Briggs & Stratton Garden
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
292 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
