Question about Cell Phones
How do I add new text message alert tones for my pantech link phone
To change the alert tone for pantech link: go to “menu”, go to “settings”, go to “profiles”, if you want it to ring and vibrate, choose “vibrate and ring” then go to “edit” which is the key at the very top left of the keypad, go down until you get to “message sound, go to “select”, “audio” and then choose the tone you want. hope that helps…i just figured it out today.
Posted on Aug 08, 2010
2 Suggested Answers
SOURCE: How do i change the text message alert tone on my
go to menu, then click on settings, open up the profiles choice..click on edit on the bottom left of screen then scroll down to message sound and select it.. make your tone choice and hit save! done...
Posted on Nov 01, 2010
How do i change the text message alert tone on my Pantech Link AT&T phone?
Oct 11, 2010 | Cell Phones
How do i change the text message alert?
By alert you mean the Tones of the Incoming Messages:
Go to Menu--Settings--Phone Profiles--Click the Arrow next to the profile you have already been using--on the top You will see an arrow facing download (a drop down menu button)--click--select New Messages--on clicking the Message Alert Tone box you will see loads of tones that you would want to select--in case if you want any song or tone that you have on you mobile to be your default message alert--select "sounds" at the bottom--select the "arrow" on the top go to the directory where you have the tones..select it and "Add" and then click "Save"
Hope it helped...Let me know if there's any problem...
Nov 03, 2009 | Samsung SGH-S5230 Cell Phone
I cant set a ring tone for a text message.
Go to Menu, Setting, Sound Profile, select profile, I prefer Normal, go to the drop down menu (you should see Call), select Message, go to Message Alert Type and choose Melody, go to Message Alert Tone and touch Tones (bottom right corner) select the tone of your preference, press Add and Save... have a Blessed day!
Oct 08, 2009 | Samsung SGH-A877 Impression Cell Phone
I want to change the ring when i get a text message i need with changing it
Click this link:
http://www.pantechusa.com/download/matrix/Matrix_UserGuide_En.pdf
This is the guide for your phone. To change the tone for messages simply go to Menu - My Stuff - Audio. Select folder, select song or sound file, select it for message/SMS tone.
Apr 26, 2009 | Pantech Matrix Cell Phone
Can you change the volume on the key tones?
under Menu ==> Settings ==> Profiles ==> Select Options and then Customize once there you can scroll down and change settings. I have discovered that when you turn the volume down on the ringtone it does not turn down the volume on the key tones or text message alerts.
Mar 03, 2009 | Pantech C610 Cell Phone
MESSAGE RINGTONES FOR THE PANTECH MATRIX
from the start screen press Right Soft Key 'Menu' > 9.Settings > 1.Profiles > Right Soft Key 'Options' (with the 'Normal' Profile highlighted) > 2.Customize. You will now be on the menu for Call Alert and Message Alert settings. Make your desired changes and be sure to save the settings when you have finished.
Mar 02, 2009 | Pantech Matrix Cell Phone
Can i set a ringtone to text messaging
Yes you can.
Just chose your fav music and select as a massage alert tone.
EnJoY....
Dec 30, 2008 | Pantech Duo Smartphone
Using a ringtone for text alert
Always think carefully about altering your phone's window registry for any reason. If you follow the instructions all should be fine. If you are a complete novice, I wouldn't recommend it, you could seriously mess up your phone. Use at your own discretion.
*WARNING I DO NOT know the extent at which this works ( "How many tones that can be added""How long the ringtones can be"FOLLOW THE INSTRUCTIONS!! I AM NOT/WILL NOT BE RESPONSIBLE FOR ANY DAMAGE CASUED TO YOUR PANTECH DUO BY PERFORMING THIS PROCESS!! Doing this involves tinkering with the phones defaults if you change something that you are not supposed to the phone may not work causing the phones warranty to be void (Solution:If your not sure what your doing DONT DO IT). Before you start make sure all ringtones you desire to be used as alerts for text messages, voicemail, etc. are in the "\My Documents\My Ringtones\" folder. This is very important as you will see. Also make sure all ringtones are short enough (15 seconds MAX) that they will be recognized as useable tones*
1. Download the Mobile Registry Editor (Don't worry it's Free) http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
2. Connect your Pantech Duo to your Desktop/Laptop and run the registry editor
3. Once your device and has been connected to the Editor open "HKEY_CURRENT_USER" (should be the second file folder down)
4. Open "Control Panel" (this should also be the second file folder down)
5. Click (and only click) "Sounds" (Should be the 15th file folder down *make sure its just "Sounds" and not "SoundCatergories"*)
6. Double Click "All Sounds"
7. In the pop up menu box scroll down to the end of the list of assorted factory tones
8. Put your cursor at the end of the last line and press enter to creat a new line to type in
9. Type in " \My Documents\My Ringtones\ " immediately by the exact name of the file you wish to enter ( EXAMPLE: \My Documents\My Ringtones\342.wow.mp3) MAKE SURE YOU ADD THE FILE TYPE (.wma,.mp3, etc.)
10. Click "OK" when you are finsihed adding your ringtones
11. On your Pantech Duo from the home menu Click Start>Settings>Sounds>Text Message then scroll through the tone options to reveal that tones you added are options and and can be play automatically!!
Reply and tell me if it worked, if it didn't, or if the directions are unclear P.S. have someone text you to double check if it works
Aug 23, 2008 | Pantech Duo Smartphone
Text Message alert???
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Aug 29, 2007 | Audiovox PPC 6700
Text alerts
pleace go to your phone menu and then select profile and open it then you see ring tone,ring tone volume,massage alert,massage tone,etc open massage alert and off it.
Jul 23, 2007 | LG CG225 Cellular Phone
Cell Phones Logo
480 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
