pilot jets are plugged, carbs will need to be removed and jets cleaned floats could also be sticking ,not allowing fuel into the bowls cleaning carbs properly will fix it ...fuel leaves a residue that plugs jets when it evaporates
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
air won,t burn ther is air between the tank & the burner try using putting a flme at the burner then tun on the burner it should start after the air passes through the hose
Immediate danger! You have a gas leak. Propane is heavier than air and will settle on the floor. The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed. Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside. Possibly you have a bad gas control valve. This should be repaired professionally.
If you have recently bought a new propane tank you may have gotten a bad one. Try taking it back to the store and asking for an exchange. The valves go bad inside the tanks sometimes.
Bad hose, bad tank, or seals are gone. Recommenend buying a new tank and new hose. The Ice is from the propane freezing and the hissing noise is a leak from somewhere. Better to replace tank and hose and try again. You do not want to take a chance with propane
