Question about Refrigerators
Door gasket on 4 year old refrigerator damaged. Can gasket be replaced or do I need to replace the entire main door??
    Genius:
  • 1,073 Answers
DEPENDS ON THE MODEL
Posted on Apr 17, 2008
Model# RT18DKXEW05 parts
Repair clinic has booth door gaskets
the refrigerator gasket is $91.60
The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
http://www.repairclinic.com/Roper-Refrigerator-Model-RT18DKXEW05-ID-114014-Gasket-Seal-Parts
Jan 29, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Door will open will not close
The door on a refrigerator is an important component to the over all functionality of the refrigerator. A simple refrigerator door repair can potentially save hundreds of dollars in energy every year.
Check the Hinges
A misaligned door hinge can release cold air from inside the refrigerator, causing it to run less efficiently. If the door doesn't shut evenly it could be a problem with a hinge. The easiest repair for this is to simply tighten the screws that hold the hinges. If this doesn't solve the problem try to see if the hinges are level. You may need to replace the hinges all together.
The Door Gasket
The rubber piece that circles the entire door serves a purpose more than just helping the door close quietly. It should form a seal that maintains the temperature inside the refrigerator. If the gasket is cracked or warped you will need to replace this. Find the model number for your refrigerator and you can find the right gasket. Some gaskets are simply put on with adhesives, others require clamps or screws.
The Light
If you have a faulty door switch, the light may stay on in your refrigerator. This wastes valuable energy. To check this simply find the switch and press on it with the door open. Sometimes a thorough cleaning of the switch can fix the problem.
By maintaining your refrigerator door and making the necessary repairs you can save yourself a lot of money in lost energy costs.
I hope this help in solving the problem....
May 08, 2011 | Frigidaire FRS26R4C Side by Side...
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Hi , my fridge door panel cracked on the side shelving area. what do i need to replace it. is this an expensive process?
    depending on the model you can buy an insert for the door which is the shelves and such, just need to replace the shell, about 32 1/4 screws around the edge under the gasket,,,,
    if you dont have them, to replace the shell, you would need to buy the entire door.
    Oct 02, 2009 | Refrigerators
    Door gasket failure
    DIY absolutely. Easy job with replacement part just re-thread the strip into the grove to replace.
    Apr 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Washer is overfilling
    If your dishwasher leaks, check these:
    Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal
    Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
    1. Lower rack
    2. Spray arm
    3. Spray arm support
    4. Wash/drain impellers
    Then pry the seal out of its housing and replace it.
    Door gasket or seal
    Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
    Water-inlet valve
    The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
    The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
    Hoses
    Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    thanks for using FixYa
    Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
    Whirlpool refrigerator stop cold but frosting bad
    Hello Catherine Fu,
    Welcome
    You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
    Help!! It is an very expensive refrigerator and ONLY 4 years old .
    First,I think you need to have a new tech.
    It sounds like you have either an air leak allowing out side air in and this causes the icing.
    Or you may need some freon (coolant gas) .
    If your freon pressure is low it can ice up.
    Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
    You need to call a different tech and let him see what's happening.
    Some company that is reliable!
    Let me know what they do for you.
    God bless, Huuum
    please remember to leave a rating.
    Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
    GE Monogram all freezer about 4 years old has a door seal that won't seal and it ices up at bottom. We have defrosted three times. Is there a way to test if the door is hung crooked?
    If the door hang is bent the door wont be vertical you can see it.
    You can try taking apart the door and mounting it back.
    More likely you need to replace the gasket.
    Sep 04, 2008 | Refrigerators
    GE REFRIGERATOR PFS22SBSBSS SHUTTING DOWN
    I too have had the top plastic latch break. A extremely poor design incorporating a hinge on a fixed point screw. We had it fixed under the extended service contract. Prior to the repair person arriving, two, not one, full sets of door gaskets and hinge assemblies were shipped to us. The repair person broke one due to his mis-use of tools. The top latch can only be replaced with the entire door gasket assembly, and he installed both in 15 min. Now the freezer handle is falling off. We installed a GE Profile Stainless kitchen in 2006 and all the units have failed. My wife literally cries over the cost for such poor design and manufacturing.
    Dec 31, 2007 | Refrigerators
    Faucet Attachment Leaks
    If your dishwasher leaks, check these:Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal
    1. Lower rack
    2. Spray arm
    Door gasket or seal
    Water-inlet valve
    Hoses
    Dec 09, 2007 | Maytag 22.1 cu. ft. Bottom Freezer...
    Refrigerators Logo
    117 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
