Question about Frigidaire Affinity ATF7000E Front Load Washer
I had a down pillow explode in my washer today and now, it has obvious problems. I stopped the cycle -- actually, the washer stopped the cycle -- wiped it out, as best I could -- and attempted to start a fresh cycle without clothes. However, it doesn't seem to be using any water and makes all of the expected sounds. I wonder whether something might be clogged. What to do?
  • 1314 Answers
SOURCE: Error code 20
i think your on the right track but a couple of things you need to know first that model washer wont spin tiny loads or one articles of clothing it has a device in the motor called a tacho generator to balance if you have only a small load it cant sense the balance and most of the time will only rock back and forth second your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water ou of the washer from the drain hose but because of the pillow this might not work in your case.now remove the two screws on the front lowerpanel and pull the panel
Posted on Jan 14, 2008
JR JR
  • 116 Answers
SOURCE: Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Posted on Nov 30, 2008
  • 130 Answers
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on May 07, 2009
  • 497 Answers
SOURCE: Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Posted on Nov 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: a pillow exploded in teh drum cleaning and it
you'll need to access the pump and remove the hoses to check the impeller and inlet screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What is the best cycle to wash bed pillows on ?? without unbalancing the drum
Hello, Thank You for using FixYa. I will be helping you today.Its not good to wash pillows in a home machine but the best would be hand wash cycle or delicate cycle
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | LG WM-2277HW Front Load Washer
WATER WON'T DRAIN PILLOW "EXPLODED"
Hi
I would need a little more info like what type of machine and model number
Feb 23, 2011 | Washing Machines
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
GE Model WHDSR209D5WW
try the pump,did the pillow rip?
Nov 04, 2008 | Washing Machines
GE Top Loader - Spin Cycle Problem
bad door switch, probably ripped out by a comforter or pillow
May 29, 2008 | GE WBSR3140DW Top Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Frigidaire Affinity ATF7000E Front Load Washer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
