My compressor doesn't turn on. My thermostat
My compressor doesn't turn on. My thermostat turns on the fan when set to auto, but it doesn't seem to trigger the air conditioner itself. I've checked the breaker...is there some type of reset switch or anything in the compressor itself? The unit is an Armstrong Concept 1000.
  • 674 Answers
There should be a disconnect outside near the unit. Check the breaker or fuses there. You can also remove the cover where the power goes into the outside unit and see if the contactor pulls in when you set the thermostat to call for air. Does the fan for the outside unit come on? If the outdoor fan and the compressor are both not coming on it would indicate that the unit may not be getting power because they both work off the same contactor. It could also be problem with the capacitor. When you check the contactor, if it isn't pulled in then your contactor could possibly be bad but there may be a couple of safety switches that keep the contactor from pulling in also. Let me know what you find and I can offer more advice based on that.
Posted on Jul 03, 2010
  • 53 Answers
You probably need a start/run capacitor. on the out side condenser unit. about $100.00 to have it fixed,
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
Cool will not come on when it's set in auto mode
A thermostat is only a switch, nothing more. It's job is to cut on and off the cooling/heating equipment based on a preset temperature setting. It sends 24-28 volts to a contactor or relay which does the actual closing (turn on) or opening (turn off) the power to the compressor or furnace, and that's all it does. There could be a problem with the other parts of the system. When the space temperature exceeds the preset temperature the thermostat should provide 24-28 volts to the compressor contactor, to start the compressor. The "Auto-on" switch on the thermostat controls the fan only. If there isn't 24-28 volts from the thermostat to the coil of the contactor, the compressor will not operate,
Oct 30, 2013 | Hunter Fan Company 42999B - Heat/Cool...
Do Goodman Split System fans turn off when the compressor shuts off? Is there a setting so the fan stops when the room reaches the desired temperature?
That is the job of the thermostat, but only if the "Fan-on/auto switch is set to auto. Look on your thermostat for the switch.
Aug 22, 2013 | Goodman Heating & Cooling
Hi, my air handler, when the thermostat is on auto will usually turn on but sometimes it doesn't. When the thermostat is set to "on" it always comes on. This has happened with 3 different thermos
Im willing to bet you have a bad relay or sequencer that energized the fan. If it periodically works when in auto im sure this is your problem. If you have a wire landed on the G terminal you should have your tstat set up as electric heat OR tstat energizes the fan rather than gas OR equipment energizes the fan.
Jan 15, 2018 | Heating & Cooling
I have a springdale travel trailer with a dometic ac system. When I turn the air on, with the fan in the auto position on the thermostst, the compressor turns on and runs, but the fan does not. The...
Neither.
The fan should run in the 'auto' position.
If it runs (on hi and lo settings) then I doubt if anything is wrong with the fan motor.
I would think your thermostat is bad and needs replacing.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Refrigerator does seem like its working right
Your refrigerator compressor is either pumping or it is not. Set the refrigerator to low temperature, pull it out and listen for a while to see it the compressor is coming on. If it is coming on then there may be a freon leak or the internal coils may be iced up. If it is not coming on, then either there is no power to the coompressor, or the compressor itself is defective. Use a voltmeter at the compressor to check for voltage. There is also an add on device to start stuck compressors from your local HIVAC jobber store.
Jun 07, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fan does not turn off even after disconnecting
Are you referring to the fan on the external mechanism, or the internal air handling fan?
The external fan is not controlled by the internal thermostat. it is controlled by the thermos-witch of the compressor. The external fan may or may not run when the motor is operating. it depend totally on the temperature of teh compressor, and not the internal thermostat.
It the internal air handling fan is running continuously,it may be a a problem with the fan setting. check if the fan is set to 'ON' instead of 'AUTO', and correct it.
Incidentally the fan operation I described, is for modern, energy efficient heat systems. This is a energy saving design incorporated in all heating systems including automobile radiator fans.
Jan 31, 2010 | Goodman Heating & Cooling
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
734 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
