Question about Whirlpool Dryers
Have a duet electronic electric dryer flashing PF display code message. Have pressed and held the HOLD TO START button, but still not restarted.
  • laurabrua Jul 25, 2010
    never got an answer regarding the time cycle issue or what to do regarding to get the control panel.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Pf error means power failure. If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code. Unplug the washer for 10-15 minutes and plug it back, if still the issue is not resolved then the control board should be checked and if bad should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • laurabrua Jul 03, 2010
    the PF code is gone but when I push the Control On button and cycle is set to Normal (Indicator light will blink at any cycle I select) the Estimated Time Remaining will appear as 34 or will change depending on the cycle selected. However the dryer will still not restart. Also the More Time and Less Time Buttons are not working. Have pressed Pause/Cancel button to retry several times.
  • Rylee Smith
    Rylee Smith Jul 25, 2010
    It is the control panel that should be replaced.
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
PF showed up - pushed and held down button - now nothing (duet dryer) barenfrow@brtc.net
"PF" means power failure you should be able to press cancel twice and everything be ok
Apr 05, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
