Correct me if im wrong but
Cant the hard drive be reprogrammed or checked while its in the copier
  • 19,396 Answers
On some copied the driver is'reprogrammed (system reinsalled) when inside the printer. If you have the service manual check if there is a service reset procedure, do that one first.
If you have a copy of the service manual on pdf, if you want you can send it to me , use this uploader
then post link here
Posted on Apr 17, 2008
How do i reprogram a harddrive to use it for a laptop
Try this... http://www.partition-tool.com/personal.htm
Aug 22, 2012 | Computers & Internet
Im Trying To Reformat My Hard Drive And It Freezes Up At 4 Percent Which It Will Not Go Further
From your description hard drive disc is heavly worn, one option you can try is a low level format, this may work and if it does it will buy you more time. If this fails it will finish your hard drive.
Mar 17, 2012 | Fujitsu Mobile MHR2030AT 30 GB Hard Drive
I had installed a wrong sound driver and when i realized that it was wrong, i cancelled the installation immediately and went through the correct sound driver. after restarting my PC, 3 error messages are...
Try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
After restore install you correct driver .
Thanks for using FixYa.
May 18, 2011 | Microsoft Windows XP Home Edition
I get a blue screen and cant log on reboots
I'm not an expert but I have had plenty of experiance with computer problems. When my Gateway had the same problem I took it to the Geek Squad (Best Buy). They called it the blue screen of death L.O.L! They said that it means the hard drive blew. I had a warrenty, but if I wouldn't have I was qouted a price of $159.99 to put in the new drive, plus extra charges to reprogram it if I didn't already have a back-up disc. I hope I'm wrong. Goodluck!
Jan 18, 2011 | Toshiba Satellite M45-S265 Notebook
I brought a new laptop HP dv3 -4010ee and now i cant open laptop , it shows insert boot disc , and press any key ,and i dont have any disc with me about hard disc.
It sounds like you've got the BIOS set to boot to CD, and/or the Boot Order in the BIOS is not listing the hard drive correctly.
Setting to boot first to CD is not a bad thing, but the next boot device after that should be the correct listing for the hard drive in the machine.
When you first turn on the machine, press the Function key noted to enter Setup (BIOS) and check those settings for correct information. DO NOT select the wrong Function key...there is another for System Recovery, and that's not really what you want to do at this point.
Hope that's helpful.
Jan 17, 2011 | Computers & Internet
I cant seem to use my 320 gb mobile hard drive. when i connect it to the usb, my laptop reads it but i cant save files into it..help me please.
try to connect your device into your pc and then, try to save files again, if this doesnt work, try to reformat your hard drive, im sorry to say that all your previous files will be deleted upon the format. after this, make partitions to hard drive. then save some of your files into it. if that doesn't work either, try a disk scan to check if your hard drive has bad sectors.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
Toshiba estudio28 call for service code f10
then call for service , I used to know their codes 20 ys ago, but a lot has changed. Imsorry I cant help you.
Jul 14, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
External Hard drive Failure
Seems to me like your MFT of FAT is corrupt. You can go ahead and do a format on it by right clicking and going to format. You should then be able to copy your backed-up files back onto the drive.
Nov 12, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
jasbo
jasbo
