Irons Logo
Posted on Jul 03, 2010
Norelco easy steam 516 but does not put out steam the way it should. Best way to clean iron
4 Related Answers
RedRanger
  • 8 Answers
  • Posted on Mar 30, 2009
SOURCE: gunk coming out of iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.
H2O Help
  • 22 Answers
  • Posted on May 25, 2009
SOURCE: Iron puts out water which stains clothes. Steam is not dependable
Replace your iron. You can try cleaning the old one with either white or the stronger pickling vinegar, but for all the trouble that will be it is easier to just replace your iron. If future use ONLY distilled water, bought at any supermarket or water store, in your new iron.
Megasom
  • 699 Answers
  • Posted on Feb 26, 2010
SOURCE: find water demineraliser for use in a steam iron
You can use cheap pure distilled water (with no additive) as used to top up car battery: supermarkets and auto shops will carry the product.
You can also make your own by investing in a water distiller but they can be expensive and the cheaper model will take about one hour to make one liter.
As a cheap alternative and easy to find alternative, use a good quality drinking water filter (jug) to make your clean product with tap water and your steam iron will still thank you!
Hope it helps!
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Sep 19, 2011
SOURCE: my Phillips gc7320 steam iron
Hi joseph mc410
Go to HomeDepot,Lowes,WalMart,any hardware store,etc.
Purchase some "CLR" mix it according to the directions on the bottle and pour it in your iron and let it work...then pour it out, flush with distilled water and you should have cleaned your iron now.
Please take time to rate me
Testimonial: "thank for you help"
1helpful
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 • Irons
1helpful
2answers
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 • Irons
1helpful
3answers
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 • Irons
2helpful
2answers
I got something on the bottom of my rowenta steam iron. How do I remove this? Can I use an SOS or brillo pad?
I would not use that type scrubbing pad. It will probably get steel fibers in the steam ports -- if you don't get them all out you could get rust on your clothes.
Try a stiff fiber scrubbing pad -- non-metallic. If you use soap, check to see if the steam ports need cleaning of whatever soap may have gotten in them.
And then maybe run some steam though the iron -- like steam iron an old rag to clean it up before actually putting the iron on good clothes.
1helpful
Gunk coming out of iron
Mar 29, 2009 • Irons
4helpful
2answers
Dz9080
A pint of white vinigar in the reservoir and steam it thro will clean it up a treat. Steam some clean water through afterwards before using it on your clothes. Best Wishes Rick
I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
