Question about Western Digital (WDXB1200BBRNN) 120 GB Hard Drive
WD 120 GB 2.5" hdd not listed in my computer
Hi, I just got a 2.5" sata WD 120 GB hdd that I plan to use as an internal in my notebook. The drive makes a click x4 after powering up as external, but it's not listed in "my computer". When I'm trying it as internal, I'm getting this message: "hard drive not recognized". I tried WD Data Lifeguard tools and the drive appears as "Generic External" when plugged in on usb post; also, Everest recognizes it as "Generic".
What can I do to initialize the hard drive? Any tool to make it visible& format it?
Thanks,
Simona
  • US_SAiLOr Apr 29, 2008
    I have the same problem. I thought it might be the usb cord and i
    bought a new one. still have same problem. I tried to use the HD again
    and it worked for me. Then when i unplugged the usb and tried to use it
    again it would not work! thanks for the help
    Scholar:
  • 180 Answers
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Posted on Jul 25, 2008
Formatting WD SATA 500GB AAKS in larger than 137GB
The best software that can fix this problem is "Power Quest Partition Magic".It works like a dream for drives of any capacity!
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Hi guys, i have a new WDbluecavier 500Gb,16Mb cache but the allocate space is 467978..so how can locate the remaining space??
This is the real capacity of your 500 GB hard disk - they are measuring it incorrectly for commercial reasons (in reality it's just 488GB) and there is a part that is reserved internally. There is nothing else.
Jun 01, 2011 | Western Digital WD HDD 500GB SATA 25"...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have transcend 2.5 usb store jet sata 120 gb hard drive which is not working , it only glows up the blue light on it
You need to plug it up to a USB 2.0 port not on a USB 1.1. There are many instructions to tell whether your USB is a 1 or 2 version but USB ports on the back usually are USB2 versions than the USB port on the front of your CPU.
The difference between both USB 1 and 2 for your Portable HDD is that USB 1 only uses 5volts power rather than the USB 2 which uses 8volts to properly revolce your SATA HDD.
Hope this helps. Thank you for using Fixya.
Jan 13, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
WD 120 Passport
Chances are that you might have to unplug and reconnect the sata line inside the case. There are many different reasons why this could be happening but the best way i can say is to start small, i.e., the lines to the HDD, connectors, etc. Now if that doesnt work disconnecting it all together from the case and connect it directly to the computer tower. Remember you have to restart your computer for this to be reconized. If this still doesnt work it will be internal on the HDD. It is possible to repair it but REALLY delicate. So if you decide to do it yourself make sure you have either a ESD strap or mat to do this on and DL Guides on how to take it apart for troubleshooting. Hope this helps ya and good luck
Jun 30, 2009 | Western Digital Passport WDXML800UE...
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
234 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
