Question about Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case
My external drive is making an awful noise, and my lap top is not reading it as disk drive G as it was before. Plus the red light is on? I can't get to any of the things I've stored on it. Help?
    Scholar:
  • 50 Answers
I'm afraid it sounds like a bad head or other simular issue that makes the drive unreadable. There are a million and one ideas out there for restoring a bad drive temporarily but usually nothing works if it is bad enough. First try it on several different machines to see if you get lucky. Also try to let it rest (no plugged in) for a while (several hours) to see if you get different results. Sometimes you can try lightly tapping it as is sometimes jars it just enough to work for a bit. If you do get it working Immediately get your data off and always plan on having a second backup, always, from now on.
There are data recovery companies that can extract the data for you if it is very important. I recommend "On-Track", however you will pay around $1500 for their services.
Good Luck
Posted on Jul 03, 2010
Backup Plus Potable 500 GB Light Blinking and disk not being read I've got a Seagate 500 GB backup plus external hard disk which is about 2 months old. The hard disk has started to make a slight clicking...
The clicking could be a symptom of imminent failure of the hard drive . Back up all information from this drive as soon as possible. It may be something that a program such as checkdisk can fix but be sure to backup drive before attempting any fixes just to be safe. Hope this helps.
Dec 31, 2013 | Seagate FreeAgent® GoFlex? Black 1TB...
I have a Sea gate free agent Go 250 GB. This was working fine till two weeks back. Now when I plug it in it makes some sort of noise but the comupter does not recongnize the external hard disk. I tried...
The noise is made by the rubbing of the reading head on the platters = mechanical defect.
There's nothing that can be done, by anyone , to fix it - it's dead and all the data on it is lost.
Dec 31, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive isnt working.the lap top isnt reading it its not going on
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The blue light does not come on the red power light flashes and the red power light flashes i see nothing on the lap top
it might have been dropped, if so it could have bent the little read pin inside causing it to not be able to function correctly, those little harddrives cant take a very big hit
Sep 18, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Can't get my lap top to open the bl--dy thing Lap top see's it but won't open it up can any one help before i put a hammer to it i've had it for about 2yrs now but haven't been able to access it now for at...
Try to connect the external disk-drive to a different computer.
If you still cannot access any files, then either:
* the USB-to-disk-drive adapter inside the case is malfunctioning,
* the disk-drive inside the case is malfunctioning.
Read the serial-number of the external disk-drive from the case, and access the manufacturer's web-site, and check to see if the "warranty" for the device is still available. If so, the manufacturer will replace the device -- you might have to pay "shipping" to send your device to them.
If the warranty has expired, open the case, remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if the USB-to-disk-drive device was the problem.
While the case is open, you could purchase a new disk-drive to fit into the case, and then close the case, and once again have a working "external" disk-drive.
Aug 16, 2010 | LaCie (300770) 250 GB Hard Drive
Makes "clicking" noise and will not mount
that is a common noise when your HD just failed it can be internal or external most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
My Dell laptop's disk drive makes a horrible noise
there is an issue in ur mouse pad/key pad...some keys are short or some keys are locked...
with respect to ur CD drive...it issue happens with the use and life of the laptop...
consult a service engineer....
or use a external USB drive...
Dec 14, 2009 | Dell Inspiron 1525 Notebook
WD External drive not recognized on computer
If the drive was running when it fell, and it doesn't have a head locking mechanism (or was in mid-read, or mid-write and the head wasn't locked down) then your disk may have experienced a head crash. The read/write heads float over the surface of the disk. If they slam into the disk, they will make a divot, boucne, make another divot, and continue bouncing until the kenetic energy is dissipated. In the places where magnetic material is removed, you won't get any data back. You may be able to recover data elsewhere, using a recovery company, but it won't be cheap. If your data is critical, you have a good chance of recovery using a service such as Seagate Recovery
http://seagatedatarecovery.com/ They recover data from all brands and I have used them They're very good, but very expensive ($800 range)
Aug 08, 2009 | Western Digital External USB 2.0 80 GB...
Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case Logo
85 people viewed this question
Top Fanner Computers & Internet Experts
Nathaniel Berrios
Nathaniel Berrios
Tracy
Harles Bently
Harles Bently
Level 1 Expert
Are you a Fanner Computer and Internet Expert? Answer questions, earn points and help others
