Question about Kenmore 67841 Electric Dryer
Turns off by itself not very hot - Kenmore 67841 Electric Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
My dtoshiba satellite pro a210 turns itself off, maybe because it gets too hot?
Suggestion: Blow system out with canned air. Those bunnies really pile up.
Oct 29, 2012 | Toshiba Satellite Pro A210-EZ2203X...
Hitachi tv turn off by itself when i get hot, how do i fix it?
Check for any air path obstructions and see if the fan is working, if not it needs replaced or checkd out. You can try and put a fan behind the unit to keep it cool this will sometimes work but the main reason is the set is getting to hot and it shuts itself down to protect itself from a failure.
Aug 14, 2011 | Hitachi 50SBX78B 50" Rear Projection...
I turn my unit on with the TV and it runs for about 15 minutes an then the unit turns itself off. I turn it back on and it last about 3 seconds and turns back off. Unit is not hot and is 4 years old.
CAPS (capacitors) on the power supply board are going bad. TV putting itself into fault protection by turning itself off..... If you can give the model number I can better help you.....
Jun 18, 2011 | Televison & Video
Plug going into outlet gets really hot
The only reason a plug gets really hot is because of an "Overload" or a "Short, or partial short" in the circuit. OR The plug body itself, is "Breaking Down" whereby, moisture, verdigris, and thermal shock, cause the "Fitting" itself. to become slightly conductive, this in turn causes electricity to "Leak" though the material, between the conductors anchor points, & because of the resistance or the material, it causes heat.
Feb 10, 2010 | Holmes Products HH970A Utility Heater
When 1993 toyota corolla runs hot will the car turn off by itself?? will it be hard to start? Why?
ya it can turn off by itself ,its will be hard to start the engine ,because the head has gone so its burn,this will make the compression in the cylinder chamber leaks,so its hard to start it
Jul 20, 2009 | 1993 Toyota Corolla
Cleaned complete machine now wont start
the starter itself should ground to the engine and the engine should ground to the battery you should trace back the ground lead from the battery to the engine if that is good use a light tester or volt meter to check your hot wire to the starter and your other hot wire from the solenoid to the switch to the battery although that should be good if you can jump it at the terminals if nothing else you can always connect a new hot wire from the switch to the solenoid if that doesn't work replace the solenoid itself
Apr 04, 2009 | Welding Tools
Kenmore 67841 Electric Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
