Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
Pump turns off when trying to backwash
Usually it doesn't cause a problem when I turn on my filter; SOMETIMES it will throw a circuit but then I can eventually get it to work. BUT when I go to backwash, it runs for about 20 sec. then shuts off and throws off my main circuit line EVERY TIME..resulting on NOT being able to backwash correctly - AND GREEN WATER!
Can I go from backwash, to rinse, to filter without having to turn the pump off and on again; I THINK that may be causing the problem. AND WHY IS there a problem with the circuit..does it really draw that much more power to backwash than to filter?
  • Amy Markham
    Amy Markham Jul 04, 2010
    thx that helped
  • 532 Answers
No, you can go backwash to rinse then to filter without having to turn the pump off and on again.
This is the step you will follow if you want to backwash.
Shut off the power. Before starting the backwash process, you need to power down the pool filter.
Thanks for contacting Fixya.
Posted on Jul 03, 2010
How do i backwash an Intex pool?
You can only backwash a "Sand" media filter.
If it is a cartridge element style, it needs to be removed and either hosed off with a pressure nozzle on your garden hose, or replace it.
If you have a Sand filter, you should have a multipart style valve that you would only turn when pump is off and place it into the properly marked "Backwash" position and then turn pump on for a few minutes, then turn back to "Filter" after rinsing.
Aug 05, 2014 | Intex Pool & Spa
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
How to use back wash
backwash is easy. dont let it scare you.
here are the steps:
-turn off pump
-roll out backwash hose
-push down on handle and rotate to backwash
-turn pump back on
-depending on type of filter, run for minimum 2 minutes (watch discharge water. run until it is clear) if there is a glass vial, you can watch that until water is clear.
-turn off pump
-push down on handle and rotate to rinse
-turn on pump and run for 30 seconds (water will leave discharge hose)
-turn off pump
-push down handle and rotate to filter
-you can run pump immediately
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
Not sure how to backwash
if its a pool,the filter shud have a rotary selector.turn pumpOFF rotate selector to backwash.turn pump on and run for 2 mins or till water runs clear.turn pump OFF and selest rinse.turn pump on for 30-45 seconds and turn pump off.with pump OFF select filter and turn pump on.take note of water pressure before n after backwash
Jul 30, 2012 | Pool & Spa
How do i get a higher flow into my pool
The low flow could be caused by a clogged filter. If you have a sand filter and the pressure gauge is reading a high pressure then turn the control valve to Backwash the sand filter until the water is clear in the waste pipe (usually for 2 to 3 mins). then turn the control valve to Rinse for about 1 min then turn the control valve to Filter.
May 09, 2012 | Pool & Spa
Blagdon 6250/backwash instructions
Turn off the pump.Ensure a hose is connected to drainage on the waste outlet of the valve assembly. Make sure there are no kinks in the hose.Turn the valve to "backwash" (usually opposite of filter).Turn the pump on and run for 2 min.Turn off the pump and run on rinse for 15 seconds.Repeat until the glass jar on the waste line runs clear during backwash.Return to filter. (If you have a sand filter, your done. If you have a DE filter, add the correct amount of DE to your skimmer return while the pump operates. An 18X34 pool takes about 5-7lbs.)
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
May 02, 2012 | Hayward Pool & Spa
My pump is on filter but is draining the water out please help
The water Has to be going out the 'backwash' or 'waste' line.Either that or you have a leak in the plumbing. If the backwash/waste valve is set in the 'filter' position and there is still water escaping through the backwash/waste line, it means that the o-ring or spider gasket needs to be replaced or re-seated. If it is a multi-port valve (one that you spin to select the setting as opposed to a 'push/pull valve) you can try shutting off the pump; do a complete turn, 360 degrees, from the 'filter' setting all the way back to the 'filter' setting. This sometimes helps the spider gasket re-seat
Nov 27, 2010 | Intex Wet Set 300 GPH Swimming Pool Filter...
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
46 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
