Question about Vacuums
NEED TO REPLACE DRIVE BELT ON HOOVER VACUUM MODEL TURBO 3500
    President:
  • 1,673 Answers
Take off the brush roll cover, then take out the screws from the bottom to remove the top lid, the belt goes from the brush roll to the motor shaft.
Posted on Apr 20, 2008
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
How do I put on belt? cleaning lady took old one off so I'm lost. It's a hoover turbo 3000.
Assuming this is an upright vacuum, the belt is located under the bottom case and runs between the motor drive pin and round the brush or beater bar. After removing the screws to expose both of these pull up on bar, wrap belt around moter drive, replace idle side of bar, insert bar into belt and stretch to drop into place.
Mar 23, 2015 | Hoover Vacuums
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My girlfriend has a Hoover upright vacuum, Mdl. # U4645-930. I need a belt for the brush and a new bulb and am having trouble finding the correct part numbers so I can pick one up locally. Can you help?
I checked with Hoover and they said the part number for the belt is #38528040, for the bulb #27313101, and they also included a part number for something called an agitator #48414081. Not sure if this is required to replace one of the other parts. You might ask when ordering. To order, call 1-330-499-9499 or online at www.Hoover.com.
Dec 16, 2008 | Hoover Windtunnel Turbo Power U4645-930...
How to change belt on hoover turbo 4600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=841267
Generic problem for all Vacuums
Posted by tbellme on July 27, 2008
How to change belt on Hoover Turbo 4600
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
