Need to find a klixon mra 98704 ? where can these be purchased ? overload/thermal protector
5 Suggested Answers
c17hydro
  • 2984 Answers
SOURCE: Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Posted on Mar 10, 2009
SOURCE: need replacement thermal overload protector
Check the Radio Shack website. Match the temperature rating of the thermal fuse.
These can't be soldered in -- the heat will blow them -- they are best crimped in.
Posted on Apr 29, 2009
SOURCE: I need a thermal overload protector #CET52ABN or ...
we have them 888-794-2365
Posted on Mar 04, 2011
  • 1388 Answers
SOURCE: I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Posted on Nov 29, 2011
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
It stoped working and well it just doesnt seem to start up again and does it need charging
It should start even if it needed charging. I do not believe foolant levels are the problem here.
Things that prevent the compressor from starting are.
1. Defrost thermostat or thermistors (Near the evaporator coils) The are supposed to terminate the defrost cycle at 60 deg F and tell the control or timer to restart the compressor.
2. Adaptive defrost controls or defrost timers.
3. PTC relay and KliXon Thermal overload protectors
4. Failed compressor windings or bearings.
If the fans are running... suspect the compressor or compressor components PTC / Thermal Overload windings or bearings. If the compressor tries to start but fails to run, it could be the run capacitor. If it just sits there and hums every 4 - 6 minutes it is most likely that the compressor has failed.
Since there was not a make or model number included with this post the answer above is quite generic. Hopefully by using the information above you can determine where the problem lies.
Thanks for choosing FixYa,
Kelly
Aug 01, 2011 | Refrigerators
When i turn on my beer machine. It turns on and then makes a click noise and shuts down. No cooling at all anymore
What your hearing is the KliXon thermal overload tripping. The compressor is not starting and the thermal overload is trying to protect the compressor.
This can be caused by 3 things.
1. A locked rotor on the compressor. (bad news)
2. A failed PTC relay on the compressor
3. A failed run capacitor.
Usually a PTC relay and a run capacitor will bring it back to life unless the compressor is actually seized.
Thanks for using FixYa.
Kelly
May 20, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Motor wont start,control circuit good fuses, ols ok motor megs good,how would I test klixon temp sensor that is wired into motor?
Power off. Unhook wires to thermal overload. use an ohmmeter or continuity tester to check it. It should have continuity or read very low resistance (<1 ohm usually)
Mar 06, 2010 | Air Tools & Compressors
Need replacement thermal overload protector
Apr 29, 2009 | Rival Automatic Steamer/Rice Cooker 4450...
Feb 28, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Heating & Cooling Logo
559 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
