Question about Amana AMV5164BA Microwave Oven
Every thing seems to operate correctly but it does not heat
It turns on, spins, and sounds like its working but it does not heat. it has done this a few times and then started working again but now its stopped heating all together.
  • Amana Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;'';';';';
Posted on Mar 27, 2011
Whirlpool microwave model GT4175SPB-2: sounds like it is running properly but is not heating up
No! by all indicators it is the magnetron and a tricky replacement. The cost to repair should be measured against a new one.
Apr 04, 2012 | Whirlpool Microwave Ovens
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Jun 19, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
Fmv156ema MICROWAVE LIGHTS UP,TIMER WORKS,BUT DISK DOESN'T HEAT OR TURN
Sounds like one of the door switches isn't working correctly. It may be bad or have been knocked out of adjustment if the door was closed too hard. You should have the oven checked by a professional. Repairs involving the door can result in microwave leakage if they aren't done correctly.
Jun 21, 2009 | Frigidaire FMV156DC Microwave Oven
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
No heat in Microwave operation
Check High voltage rectifier diode if it is ok replace the Magnetron.
May 03, 2009 | Panasonic NN-9804 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Amana AMV5164BA Microwave Oven Logo
74 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Gareth Cockram
Gareth Cockram
Steven Clarke
Steven Clarke
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
