Question about Acer AL1916W 19" LCD Monitor
Moniter displays for few seconds then goes blank
I have been having problems with my lcd lately. It will show briefly and it goes off. The green light will stay on. Any help please..
  • 11,361 Answers
Look for bad DC filter caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 04, 2010
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Problem with moniter
i have BENQ lcd 15" monitor, the problem is that the menu appear atomaticaly
Aug 25, 2008 | BenQ FP71G 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
