Question about Canon NP 7130 Black and White Copier
Canon np 7130 drum installation
How easy is it to install a drum unit into a Canon7130? Should I try, or have a tech do it?
  • Canon Expert
  • 287 Answers
Hello joeboo123,
The fact that you had the foresight to ask the question leads me to believe you can do it.Your question was is it easy. Well, its one of those things that is easy to anyone who has done it before. My suggestion would be to order the drum/developer cartridge, instructions are enclosed. This device was designed to be to a large extent consumer serviceable,and the drum is one of the items. I have to admit it is more difficult than Canon seems to believe it is. However, if you take your time, you can do it. The drum unit is to a large degree protected from mild probing. So you can fart around a little as you try and as long as you dont force anything you will be ok. In my opinion you ,at a minimum will be able to purchase the drum without having to pay a 3rd party. And in the event you find that you can't install the drum or just plain feel uncomfortable, you can always call in the calvary. At least you will have purchased the drum without paying the copier dude (I AM ONE LOL ) and his company the additional mark-up on the item. Again, it is awkward to install the first time. Just take your time. When it falls into place you will grin like a set of high beams. I have been working on copiers for over 20 years, which means nothing. I mite have left a trail of disaster for 20 years for all you know. But I am being honest that I believe you can do it. Take care and good luck. ............spinal...
Posted on Apr 18, 2008
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Jul 25, 2012 | Canon NP 7130 Black and White Copier
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
How do you install the npg-11 drum unit
To hold the spring you have to put a screw in place of pin plastic broken, carefully removed the main PWB, really damaged location.
Apr 18, 2010 | Canon NP 7130 Black and White Copier
Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Sep 01, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130
first try to look for the drum if it scratch no matter the distance btn lines
then if the drum is ok. look and adjust the position of the lens to home position.
Aug 07, 2008 | Canon NP 7130 Black and White Copier
CANON NP 7130
This is your drum unit or transfer unit that must be replaced.In what area are you?
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Poor quality copies from the Canon NP 7130F
hi im jules_09.have check the drum unit and the fuser unit check the two unit.first of all the drum unit the drum may be scratch or damage that goes with the fuser unit too.
Dec 12, 2007 | Canon NP 7130 Black and White Copier
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
162 people viewed this question
old marine
old marine
