I have a heil 5000 high effiency model ac unit. Does my unit have to match the coils in the furnace? Or can the btu's be the same as my old unit and have it work fine with the coils inside?
  • 53 Answers
Have to match coils. The new one probably uses R22, or A400
Posted on Jul 03, 2010
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Iinstall a new 2.5 ton condenser unit, cooling coil and a 90,000 btu furnace in my condo. I have charged the system with R410 Refrigerant. The unit is not getting as cold as I suspected. Is there...
first, obtaining the correct charge is rather tricky .. it depends on inside and outside temperatures and humidity .. you need gages to measure both high side and low side pressures accurately and match those figures up to a chart that considers inside/outside temp and humidity ... in a new install you can calculate the required charge based on numbers given by the manufacturer modified by the length of connecting pipe set ... before charging, the system had to be vacuum pumped for an hour or more (unless the system came precharged) .. all vents in the house should remain open for air conditioning and the furnace blower speed chosen for a specific temperature drop across the cooling coil .. some AC repair people dont know how to do all that properly .. it takes a true professional to optimize the system .. if you can find someone that really knows how to do this then you might try to bargain for a good price for him to just trim you system ..
Aug 15, 2010 | Whirlwind FH-778 Air Conditioner
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
Ruud Furnace needs replacement
What part of the country?
How many square feet in the house?
Insulation?
Single pane glass?
Many factors should be considered by a professional.
However if the old unit worked OK, a new 80% 70,000 unit will most likeley replace a 24 year old 60-70% 75,000 unit.
Dec 14, 2008 | Carrier 38CKC042 Air Conditioner
16 year old Heil 75K btu furnace, some times does not ignite.
recommend getting a carbon monoxide indictor or having some one test it. with it being over 15 yrs old if checks good replace ignitor assy should fix it ok
Dec 14, 2008 | Cross Furnace Draft Inducer Blower 115...
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
