Question about Dell Latitude D600 Notebook
Dell d600 video problem
My customer was attempting to use her latitude d600 to drive a external projector for a seminar. Somehow she managed to lose video on both the internal lcd and the external display. Upon booting you have video until Windows XP loads (and presumably the point where the video driver loads) then the screen goes blank while the system continues to boot up. The Fn + F8 keys DO switch activity between the two monitors but there is no display. Also, in safe mode it will boot just past MUP to AGP440.SYS and there it hangs. Tried switching modes in BIOS but it's PW locked. The customer says she dissabled something in the monitor settings but can't remember what it was!!
  • printer guy Apr 17, 2008
    I really appreciate your response however, the passwords, as I understand, are stored in an eprom that isn't affected by discharging the battery. I was finally able to get around the situation by using one of my xp boot cds to get me to the maintenance console. From there I replaced the registry files necessary to enable a startup, and ultimately was able to drop back to a previous snapshot from 2 days ago. I don't have any idea how she (my customer) managed to lose video on both the internal and external monitors but it's resolved now. Thanks again!
  • One Million Network Inc
    does she remeber the bios password?
    Genius:
  • 1,027 Answers
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Posted on Apr 17, 2008
  • Mark Williams
    Mark Williams Apr 17, 2008
    Dell Latitude D600
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
May 20, 2010 | Dell Latitude D600 Notebook
Restore dell d600 to factory settings
Resetting a Dell Latitude to the factory settings allows the user to restore the Dell Latitude to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Latitude laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Latitude laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Latitude reset process...
This process will erase all your previous changes that have been made to the Dell Latitude laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance
for all models of Dell laptops(Vostro, Latitude,Inspiron...etc..) at http://www.vtechsquad.com/dell-support/
Mar 25, 2010 | Dell Latitude D600 Notebook
I intstalled a new hard drive. When I attempt to
Make sure you have a compatible hard drive. They're not all the same.
Dec 08, 2009 | Dell Latitude D600 Notebook
Presentation mode is off appears when you try to FN F8 Dell Latitude E6500
check device manager to be sure your video card is functioning properly. If it looks good in device manager, shut off the pc, connect the external monitor/projector to the pc and start up the pc with the external device powered on. if no video from external device, then the video card/external connector is probably bad. Contact Dell if in warranty.
maybe the fn/f8 keys are not working. Can you get a safe mode boot prompt by repeatedly pressing the f8 key immediately following power up on the laptop? if no, f8 key is likely dead and you need a new keyboard. If f8 is okay, does the fn key work with other functions? if no, fn key is bad - new keyboard.
Hope this helps!
Aug 08, 2009 | Panasonic PT LC75U Multimedia Projector
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Where is wireless switch located on latitude d600
press function (Fn) then the F2 key. but if ur wireless card was not properly installed this will not work...
Apr 12, 2009 | Dell Latitude D600 Notebook
How to output the monitor.
Fn + F8 will toggle the VGA port on the back if the System, Press a 2nd time, External and LCD, press again, LCD only again. (Wait about 15 to 20 seconds for the external port to initialize after pressing Fn+F8 as it has to detect the projector)
Apr 04, 2009 | Dell Latitude D600 Notebook
D6OO DELL LATITUDE DRIVER
The Dell website under the support section will have the drivers you need. Hope this helps.
Dec 23, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
320 people viewed this question
Alun Cox
