Kenmore Washer 60 series 110.91565110. Won't rinse or spin. ~ Greg
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The washer will not spin/rinse if it cannot drain the tub first. To start with check the drain pump for any clogs/obstructions; also check the drain hose for any blockages. After this is done check the drain pump motor and drain pump, also check the wire harness from the CCU (central control unit) to drain pump and replace the part that has gone bad.
If it wont advance then it is the timer/control panel that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • aoplus Jul 03, 2010
    How do I check the wire harness from the CCU (central control unit) to drain pump to know if has gone bad?
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Washer won't spin the water out after the rinse cycle
Probably the filter is clogged. It usually is at the bottom of the washer, either at the front or at the back of the washer, it normally looks like the fuel door of a car. You must open the metal door, release the lid (maybe at this point some water will come out) and then clean it. Put lid back, close the little door and try again with the rinse stage.
Good luck
Mar 24, 2012 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
