Question about Echo CS400 18" Chain Saw
Is there an easy way to put the pull cord spring back on?
    Brigadier General:
  • 4,088 Answers
No, you have to connect it at the inner point, then wind the spring around keeping it fairly tight all the time. You will eventually be able to reconnect at the outer point on the spool. Usually, it's best to remove the starter cord from the spool until the spring can be attached. Wedge the spool so that it can't unwind the spring and refit the cord (make sure it is in good condition). Usually best to remove the handle to facilitate the stringing process. Make sure there is enough slack in the spring so that it can be tightened at least 4 turns more (when pulling the starter). Melt the cord ends a little to prevent the knots from pulling out with use. This is something like setting a bear trap, so use care at all times. Good luck!
Posted on Jul 04, 2010
The pull starter cord will not pull past 6 inches
The same thing happened to my lawn mower. Turned out to be a simple problem. The cord had slipped off the spool inside the cord housing and caused a knot. Try taking off the pull cord cover and unravel the cord all the way, then put it back on making sure you don't twist it around much, and that you put it back the same direction (counter clockwise / clockwise). If that doesn't solve the problem, at least you'll be able to inspect the cord and spool, and replace either if necessary. P.S. I would highly recommend NOT taking the bolt out of the spool unless you have to, I made that mistake, once, and let me tell you, putting that "clock-spring" back in is not easy if it unwinds. Hope that helped. Grimm
Mar 12, 2015 | Garden
How to remove the cord on my lown boy ?
Where the Starter Cord goes in to the top of the motor is what you need to remove. It is where the motor draws cooling air from and it is easy to remove. There are 3 or 4 small nuts (depends on HP, My 8.5 has 3. My 14hp has 4.) After you have it in hand, turn it over and you see the round pulley, take your time, there is a spring that pulls the cord back and sometimes it will just unwind with a lot of noise.
Don't worry as it is easy to do after installing the cord.
Now is the time to take a break, have a cold beverage!.
Then just put everything back together.
OOPS, I forgot to tell you that you can test the cord and retract spring without putting it back on the motor, and if you need to adjust the spring so it will pull the cord all the way in.
Good way to start learning about your mower.
Jun 27, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Pull cord broke
take the string attachment off there are 3 or 4 small bolts , maybe 5/16 take them off or it may be riveted drill them out fix cord rewind spring right ,put back on with the bolts or put new ones on , good luck easy job
Mar 13, 2014 | Toro Power Clear 621E - 38452
I tried pull the cord stuck took it apart spring ok.the shaft from engine stuck,
Sounds like you have a bearing failure, eithe big end or crank shaft bearing. When they go they quite often knacker the piston and cylinder too as it can put them off square. Remove cylinder and the problem will be easy to locate as you can see the big/small end bearings and check for cylinder damage. Often the cost of repair far outweighs the value of the equipment.
Apr 07, 2013 | Husqvarna 128 LD Weedeater
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
How do you replace the pull cord on a McCulloch whipper snipper Mt325CLS
Generally this happens either because the spring has broken, or the mechanism is full of dust and rubbish that jams everything up. While I am not familiar with your particular model, they all tend to be very similar. You undo a few screws to remove the cover and expose the pull cord mechanism. If the spring is broken, take note of where the ends are connected to, buy a new spring and then put it back the way the old one came out. This is not as easy as it sounds, as you need to wind tension on it. It in doubt take it to the dealer. The job will take less than half an hour so shouldn't cost much.
Nov 28, 2011 | Garden
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Echo CS400 18" Chain Saw Logo
208 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
