Question about LG WM2688H Front Load Washer
We went to clean out the filter and found that the tube that normally drains the water is completely clogged. Is there a way to get to the other end of this tube so we can clean it out? We've already tried sticking wire up the tube, but it is insufficient. LG WM2688H*M
  • 10,319 Answers
These tubes are so difficult to clean we replace them with a new one instead. You can try and soak this in a pail of peroxide for an hour. I have tried that on a few when the hoses were on back order. Some came clean and some did not. I would recomend very hot water (boil first and let stand for a minute) Then soak it for 15 minutes. It might break up the clog if your lucky
Let me know the outcome
Posted on Jul 03, 2010
  • jynessjones Jul 03, 2010
    how do we get to the other end of the hose in order to try this?
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Jun 19, 2015 | Frigidaire Washing Machines
Water left in tub at end of cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | LG Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
I have a Matsui MF2W dishwasher that will not drain. Theres always water in the bottom. The exit tube rises to the pipe at a height of 90cm which is < 100cm as ststed in the manual Could it be blocked?...
Hi
Daniel
Jul 21, 2011 | Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
May 11, 2009 | LG Washing Machines
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Frigidare Ultra Quiet III Dishwasher won't drain
To properly drain and clear out any clogs in a dishwasher: 1.Take a wet/dry vacuum, remove the paper air filter (usually just a screw) from the inside of the vacuum body 2. Empty out the vacuum body prior to using it.  3. Then **** out all of the water from the inside basin/tub.  4. Before you turn off the vac, lift the hose high into the air and make sure all of the water is sucked into the vacuum to prevent any water still in the tube from making a mess.  5. Dump that water. This will provide you an opportunity to remove excess water before you get to work.
Next, under the sink there you will see your drain, just above your drain you will see a black or transparent tube about 1" in diameter.  6. Unscrew the tube screw.  7. Get your vacuum hose and hold it near the tube. When you take off the tube, there may be, though likely not, some excess water in the tube. **** this up if needed.  8. Put the vac hose onto the tube and make an air tight seal with your hand over the hose and tube.  9. Turn on the vacuum and such out any clogs.  10. Turn on your dish washer and let it run for a minute or two to get water back into the tub.  11. Open the door, there should be about 1-2" of water in the tub.  12. Hit the cancel button and let the water pump out of your tub, be sure to hold the vacuum hose over the tube and **** out all the water with the asistance of your dishwashers pump.  13. Repeat steps 8-12 2-3 times. You should notice water will no longer remain in the tube when you fill it up, & press the cancel button because the machine will pump everything out for you. Once you have done this and the water pumps out without a problem you have fixed your clog.
14. Reattach the tube to the drain using the tube screw. 15. Dump the water from the vacuum down the drain. 17. Clean up and put your vacuum away. 16. Put the $95 into your savings account because you likely just fixed your clog in under 45 min. from start to finish.
I hope this helps!
Dec 28, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Sep 18, 2007 | Jenn-Air JCD2295HES Side by Side...
LG WM2688H Front Load Washer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
